Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mustang II rack attachment
Old 06-27-2012, 08:42 PM
jfmmck's Avatar
jfmmck jfmmck is offline
jamie
To get it centered, make sure you have the same amount of rod sticking out on each side of the rack body ( may require you to pull the boots off). simply turn steering shaft to get equal lengths. Then measure end to end and mark center point on rack. The tie rod ends can be screwed on exactly the same number of turns each to get you tires so you have about 1/4 toe in. That should get you to the alignment shop if you don't trailer it. The stops will be placed to keep the tires from contacting the frame or the rack from bottoming out, whichever is first.
