-   -   Mustang II rack attachment (http://www.hotrodders.com/forum/mustang-ii-rack-attachment-217286.html)
T Evans 03-25-2012 10:30 AM
2 Attachment(s)
I've installed a Fatman's Mustang II manual front end and steering rack on my 1950 Jeepster. How tight should the 2 bolts that go through the rubber bushings that hold the rack to the cross member be? I've hooked up the steering column and notice some movement in the rack when turning the steering wheel. Thanks, Tom
matts37chev 03-25-2012 07:04 PM
is that the bushing i see in the first pic?
is there a sleeve inside that bushing for the bolt to tighten down onto?
if not, i would tighten it so the bushing squishes up to about 2/3 to 1/2 the the thickness it is now
T Evans 03-25-2012 08:10 PM
Yes, there is an inner fiber sleeve that fits inside the rubber bushing. Thanks, Tom
timothale 05-07-2012 09:51 PM
rack bolts
In the factory there was about a 125 lb monster air power tool that torqued the rack nuts then crimped them so they wouldn't work loose. I would use locktite when installing them.
jfmmck 06-25-2012 07:40 PM
I tightened my bolts till the rubber bushings were crushed to about 1/2 in between the washer and sleave. I have 5000 miles on the vehicle and no movement or loosening of the bolts. By the way, my rack came with lock nuts and if yours did also, they won't back off.
boatbob2 06-26-2012 07:38 AM
Slight subject change.......
Hi,i have a Fatman Mustang 2 suspension in my 48 ford coupe,the rubber bellows on the R & P, fall apart in less than a year,(Probably chinese) where can i buy ones that will last awhile???
V8Square 06-27-2012 08:16 PM
How do you figure the exact center of movement on a Mustang II steering rack? What dictates the steering stops?
jfmmck 06-27-2012 08:42 PM
To get it centered, make sure you have the same amount of rod sticking out on each side of the rack body ( may require you to pull the boots off). simply turn steering shaft to get equal lengths. Then measure end to end and mark center point on rack. The tie rod ends can be screwed on exactly the same number of turns each to get you tires so you have about 1/4 toe in. That should get you to the alignment shop if you don't trailer it. The stops will be placed to keep the tires from contacting the frame or the rack from bottoming out, whichever is first.
V8Square 06-28-2012 06:16 PM
Dumb question. Are there stops that are bolted to the rack somehow?
jfmmck 06-28-2012 08:02 PM
No stops on the rack itself. I don't know where they are on the Fatman set up, I have a Heidt. The Heidt has some tubing (1/2 ID) welded on the front of the lower controll arms that accept an adjustable stop. I put a bolt with a nut on each side of the tubing. The tie rod ends come in contact with the bolt head.
V8Square 06-29-2012 06:29 AM
Thanks for the info. Can you send me a picture?
S10xGN 06-29-2012 08:45 AM
The T-Bird rack in my Maverick (RCMotorsports front clip) has internal stops. To center everything up, I put everything together then turned it full left and measured from the inner tire to the frame rail. Now do the same for a full right turn. Once you have these measurements, you can adjust the inner tie-rod ends to make both sides even. After evening them up, you'll need to remove and reorient the steering wheel.
There are prolly other ways to get there, this worked best for me with minimal fuss...
Russ
RatPin 09-19-2012 07:12 PM
Those bushings are meant to spread when tightened down if I remember correctly. Torque them good. They should flatten to the size of that washer or more.
Irelands child 09-19-2012 08:41 PM
Why not just pick up the phone and CALL Fatman Fabrications instead of getting 'I Think' it should be ........
Their phone number is 1 704-545-0369
454 Rattler 09-20-2012 08:31 AM
It seems like we're kicking a dead horse again.
The question was asked 6 months ago and the OP never returned.
I wish people here would come back and tell us if the problem was fixed or not.
Maybe they could just say thanks.
Irelands child has the perfect answer for most situations.
Thanks !
454 RATTLER
