Mustang II rack and pinion to GM pump install - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2011, 11:31 AM
I have installed a mustang II power rack and pinion and a GM pump. I just tried bleeding the system and in countered alot of jumping of the wheel and tires as I turned the steering back and forth. I have changed the pump pressure with a Borgeson kit (4 shims) should be about 1000 PSI. Ideas?
Old 09-17-2011, 12:10 PM
35terraplane's Avatar
Mustang rack
Did you put the valve in to reduce pressure from the Gm pump. If you have a Mustang rack you have to use one. If you use a T-Bird rack and a gen II pump, you do not need one.
You can find them in speedway.
Bob
Old 09-17-2011, 01:13 PM
I assume I have a mustang II rack and pinion and I've been told then TB and mustang are the same ( assume and here say not so good). I did alter the valve with a shim kit. Since my first post I checked the fluid level and noticed lot of bubbles in the fluid, so I did the bleeding again. My new Question is does the jumping indicate air in the system?
Old 09-17-2011, 01:31 PM
Mustang rack
There's a good chance, you might have air getting into system.
The TB- racks from the, I think mid 80's to early 90's will work without the valve, and using what they call the GM GEN II pump. Speedway as every thing you need for them.
Bob
Old 09-17-2011, 02:14 PM
I'm going to bleed it again in awhile it seem to get better each time, must be air in the system still.
Old 09-17-2011, 08:14 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Before you do anything I would check and see if you have the hoses swapped on the rack!
Old 09-18-2011, 08:09 AM
Hoses are right ( pressure to the front return to the rear) I think that everything is OK, I ran it again last night and all was well. It seems that letting it sit between bleeding sessions does slot of good, no more bubbles in the fluid--- Thanks to all for the help
Mustang rack & pinion John Ragazzo Suspension - Brakes - Steering 1 04-28-2007 06:34 PM
Rack & Pinion Install joeford Suspension - Brakes - Steering 10 11-29-2006 04:21 PM
67-69 camaro rack-pinion install rick17 Suspension - Brakes - Steering 1 11-27-2004 12:19 PM
Flaming River Rack & Pinion Install in a 67 Mustang fastbackford351 Introduce Yourself 1 11-10-2004 10:51 PM
Mustang Rack and pinion Pro Street Suspension - Brakes - Steering 0 02-05-2003 04:59 PM
