Mustang II rack question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2009, 12:21 AM
vanislander's Avatar
A couple of questions for the experts out there. I just put a new power rack in my 34 ford and was wondering what I should torque down the two mounting bolts to?, don't want to over torque. Also has anyone had problems with the fluid line to the power fitting leaking, the fitting has a small washer with a rubber O ring in it , but the washer is too big to fit down into the recess on the rack unit, so it isn't compressing properly and there is a small leak.
Thanks.
Old 09-30-2009, 07:18 AM
302 Z28's Avatar
Whose rack is it? When I installed mine I just pulled it up snug and tightened it up a little more.
Vince
Old 09-30-2009, 10:07 AM
Hi Vince,
It's a TCI rack, not sure what it's out of as these are reconditioned units,
Thanks,
Denny.
Old 09-30-2009, 11:48 AM
S10xGN's Avatar
Gotta love a turbo!
Thanks.
The smaller (high pressure) fitting should have a nylon or copper crush washer type seal, the larger (return) has only an O-ring...
Russ
mustang II rack Lil John Suspension - Brakes - Steering 2 04-30-2008 08:35 PM
Steering rack installation question Rons1stRod Suspension - Brakes - Steering 7 11-07-2007 08:52 PM
mustang II steering rack 35chev/302gmc Suspension - Brakes - Steering 1 07-08-2005 06:24 PM
Mustang II ball joint boots jaxhome Suspension - Brakes - Steering 24 04-04-2005 07:35 AM
Wheel Spacing/ Mustang II Question Jackyl General Rodding Tech 1 04-25-2003 06:10 PM
