Mustang II rack question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2012, 11:47 AM
Last journal entry: Volkswagen V8 Squareback project.
I am building my tube chassised, V8 powered, Mustang II front suspension Volkswagen Squareback body, hot rod. I have a question on the steering rack (being this is my first project like this, I have many questions). How do I get the rack in the straight ahead position? That is, on a VW steering box setup, there was a mark on the pitman arm and on the steering box you would line up, but on a rack, I am unsure. How are the steering stops figured? Any advice is greatly appreciated.
Old 05-12-2012, 08:42 AM
Handfull54's Avatar
I would check with a shop that builds chassis for a living. You could check with Rob at NO Limit Engineering in Riverside, CA. He is very knowledgeable about suspensions and a nice guy. He can probably point you in the right direction.
Old 05-12-2012, 10:39 AM
Thanks. Do you know if he has a web site / email address?
Old 05-12-2012, 11:53 AM
Handfull54's Avatar
You can just look up No Limit Engineering on your computer and get his web site.
Old 05-12-2012, 08:13 PM
If I understand you right, you're simply trying to determine where center of the travel is for the rack. I'd just go lock to lock, count the turns, divide by two and back up that many turns from one stop or the other. That should put the rack in the center.
Old 05-13-2012, 08:09 PM
Thanks. I'll give that a try. Another dumb question. How is the steering stops figured out? That is lock to lock.
mustang II/ thunderbird rack question sfd771 Suspension - Brakes - Steering 7 05-12-2012 08:57 AM
Mustang II rack question vanislander Suspension - Brakes - Steering 3 09-30-2009 11:48 AM
Mustang II power steering rack question heyjude076 Suspension - Brakes - Steering 8 12-18-2008 04:39 AM
mustang II rack Lil John Suspension - Brakes - Steering 2 04-30-2008 08:35 PM
Mustang 2 rack new vs. used Dave 39 Suspension - Brakes - Steering 2 01-07-2008 08:20 PM
