Mustang II rotor 11" with a 4.5 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2010, 05:00 PM
Footstomper
Last journal entry: 40 ford/cadillac coupe
I have a 40 ford coupe, updating the front from 40 original, to the mustang II, I want the original wheels, 5 1/2" pattern from 4.5". I knocked the studs of the rotor, put the 11" rotor, added the caliper, put the 40 wheel with the sweet 16" radials. I have clearance when I put it all together. I called my speed shop and asked if they can drill the rotors to 5 1/2" pattern. I understand that the 5 1/2" may have to drill into the walls of the rotor hat and use the studs, they match the 40 threads.
Does anyone have a better idea. Don't throw money right now, I just to get on the road. I have looked at everything with around 600. The drilling is 120.
Old 04-09-2010, 05:48 PM
Wiki Edits: 31
http://www.speedwaymotors.com/Wide-5...ters,3444.html
Old 04-09-2010, 07:26 PM
Footstomper
I saw that today, I thought that I could switch to the ford 1936 to 1939, those are the wide 5, simliar of the VW rims in the early beetle. I feel that I have spent too much, I just want to know of anyone drilling the studs to make it to fit my 1940 wheels, just on the front. Just ten holes in the wheels pattern of 5 1/2".
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Mustang II front shocks not "tall" enough BobbyG-39 Suspension - Brakes - Steering 8 08-10-2004 05:36 AM
Mustang II pressure regulator Chev283 Suspension - Brakes - Steering 1 07-14-2004 02:13 PM
Mustang II bump steer, drifting Chev283 Suspension - Brakes - Steering 2 06-19-2004 08:15 PM
Mustang II suspension components DossWallace Suspension - Brakes - Steering 7 04-04-2003 12:11 PM
