Mustang II spindle to rotor shim? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2005, 05:21 PM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
Has anyone ran into rotor rubbing on spindle when assembled?
What my problem is on another mustang II set up I have is during assembly I noticed that I could not set the drag on the rotors. When tighting nut on spindle rotor would stop spinning, but rotor was still loose. I noticed the rotor is actually rubbing the spindle. The set up is a Heidt's with 11 inch rotors and stock spindles (actual Ford).
Somebody has told me there is a 3/16" shim that goes on the spindle before installing the rotors. Has anyone heard of this? I didn't have to do this on my Willys.
Jason
Old 07-30-2005, 07:38 PM
aka Duke of URL
Are the rotors GRANADA or GM?
Old 07-31-2005, 03:19 PM
41willys's Avatar
Blowin' it
Wiki Edits: 11
That would help wouldn't it. Yes they are gm 11". Sorry, should have noted that initially.
Old 07-31-2005, 07:39 PM
aka Duke of URL
OK...When you get away from Genuine FORD, I have little clue. Most times I stop reading a post when GM is mentioned as naturally it doesn't interest me. But I have read about spacers being available to move the inner cup outwards so the rotor hub will clear the spindle (on GM rotor crossover).
One of these fine GM Gentleman should be able to advise you from here...
Old 08-03-2005, 05:26 PM
You use some different parts for this conversion and off the top of my head, I cant give you the particulars. The seal is different and either the inner or outer bearing is different. I'll look through my build books to see if I can find the part numbers for you.
Trees
Old 08-03-2005, 05:40 PM
OK, dug it out. Good thing because both bearings are MII. It is the inner dust seal that give you the spacing. It is Federal Mogul # 471854. The dimensions are 1.937X1.561X0.50. The .50 thickness should do the trick for you.
Trees
Old 08-05-2005, 07:10 PM
41willys's Avatar
Blowin' it
Wiki Edits: 11
Hey, thank you very much
Jason
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Mustang II front shocks not "tall" enough BobbyG-39 Suspension - Brakes - Steering 8 08-10-2004 05:36 AM
Mustang II bump steer, drifting Chev283 Suspension - Brakes - Steering 2 06-19-2004 08:15 PM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 04:08 PM
