Mustang II spring question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2011, 01:23 AM
I will be replacing lower control arms on a car that has had a mustang II upgrade long ago... My question is will I need to do anything special with the springs when I pull things apart?? I know when I pull the arms off of my falcon I have to relieve the pressure on the springs...
Drag
Old 03-09-2011, 05:28 AM
You need to control the spring. Spring compressors are the best way to do that, but I have controlled the spring by keeping a floor jack under the control arm with the car supported by jack stands under the frame. Once the ball joint is broken loose, lower the jack until the the tension is off the spring. Of course the shock was removed before starting the process unless you want it to serve as a safety net in case your jack slips. Re install by reversing the process.
Trees
spring question 383SBC Engine 7 02-20-2010 04:13 PM
valve spring question bracketracer Engine 5 04-05-2009 07:00 PM
valve spring question Casperdude898 Engine 2 04-07-2008 01:38 AM
MUSTANG II Spring installation 1947chevypanel Suspension - Brakes - Steering 9 01-12-2007 09:16 PM
spring question tweaked Engine 7 03-10-2005 11:18 PM
