Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mustang II springs
Old 11-24-2001, 10:20 AM
Phat's Avatar
Phat Phat is offline
Toy builder
Willy i do suggest only cutting 1/2 coil at a time. Do the shocks last. Post back if yah need more help.Rule of thumb the 4 cyl springs are soft but work ok when cut(the rate goes up as you cut them shorter)If you start with V8 springs and have to cut them much the rate gets rather high(600-900 lbs)
Good luck Bud
