Mustang II: Springs rubbing shocks. Help me please - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-03-2012, 09:51 PM
ogre's Avatar
the 'Duracell Project'
it will look like that until you get the weight of the completed car on it and level out the lower arm.
  #17 (permalink)
Old 04-03-2012, 10:20 PM
Cape Cod Bob's Avatar
Looks like the wrong springs. Go to NAPA site for correct deminsions.
The lower A arms should be parlelle to the xmember when the full finished weight of the car is on it.
  #18 (permalink)
Old 04-03-2012, 10:46 PM
Vetteman61's Avatar
Last journal entry: Moving my Journal
OK, guys, I finally got it figured out. There were two problems.
#1) I got online and tried to find some pictures of installed chassis engineering kits. I noticed that one of them had the top hat spring mounts all the way up. I had tried to screw mine up further but they wouldn't go. Turns out I had to put a bit more force behind them. I got them quite a bit further up (which would lower the car) and it gave a lot more room.
#2) Tracy pointed out to me that I had the spring upside down. When I turned it over (which after I thought about it made a whole lot more sense) it gave more room yet still.
After that, everything went together smooth as silk. I have some pictures posted in my photojournal of how it looks now.
Thanks for everyone's help,
Brandon
  #19 (permalink)
Old 04-04-2012, 10:49 AM
spacytracy's Avatar
Last journal entry: 1957 Chevrolet 3100 Truck Small Window to Big Window Conversion
Great thing about doing all of this yourself is that you will be some what of a pro in many different areas by the time you are done building your car. I did not have a clue about suspension, or engine building or welding until I tackled these projects one at a time. This site really is great for getting through some of these first times with help from those of us that have been there done that!
  #20 (permalink)
Old 04-04-2012, 07:52 PM
Did u use the stock upper spring pads. Makes a quieter ride.
  #21 (permalink)
Old 04-04-2012, 09:02 PM
Vetteman61's Avatar
Yeah, I really appreciate all the help. One problem I tend to have is that I am basically learning everything as I go so some people get confused with I know how to install certain difficult parts and then I don't know how to do other very common things and they skip over a lot because they assume I must know it. I wanted to build this whole car because my wife and I intend to use it as a family car for as long as possible so I want to know every inch of it so I can work on it myself. I believe if you want something done right you have to do it yourself, so that's our plan.
I did use the spring pads that came with the kit. They fit up under the top hats.
Thanks,
Brandon
  #22 (permalink)
Old 04-05-2012, 09:20 AM
Wiki Edits: 49
Thanks,
Brandon
You want to keep a detailed notebook of everything you do and what parts are in it. It's a pain down the road when you need a new belt and can't remember what one you used last time. I kept the receipts for every part and detailed records so not only do I know every part in my deuce, I also know how much I paid for them. Completely filled a 3 inch 3 ring binder. Total just for the parts was just over $22,000.
Centerline
HotRodsAndHemis.com
"If money is what makes cars fast, mine otta be going 400 miles an hour!". - Felix Sabates
  #23 (permalink)
Old 04-05-2012, 11:21 AM
Vetteman61's Avatar
Yeah, that's a good tip. I'm doing the same thing. Since this will be my wife's daily driver I definitely want her to be able to have the car fixed if something were to ever happen to me.
Brandon
Coil over springs and shocks Tim34FSD Suspension - Brakes - Steering 2 12-02-2008 08:38 AM
Coil over springs and shocks Tim34FSD Suspension - Brakes - Steering 0 11-26-2008 03:45 PM
How to pick the right springs/shocks? VolvoGuy Suspension - Brakes - Steering 2 03-19-2006 12:22 AM
New springs/shocks keolab1983 Suspension - Brakes - Steering 2 01-18-2005 12:47 PM
springs and shocks? chevelle327 Transmission - Rearend 0 11-20-2002 07:54 AM
