Mustang II: Springs rubbing shocks. Help me please - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2012, 09:05 PM
Vetteman61's Avatar
Last journal entry: Moving my Journal
Hello all,
I've installed a Chassis Engineering Mustang II front suspension on my 1937 Chevrolet 4 door. After getting my springs finally compressed I (which was a pain) I had a lot of trouble getting my shocked bolted up because it was contacting the inside of the spring. After finally getting it bolted up (with help) it is still making contact with the spring.
Has anyone dealt with this before. Is this a big problem? Any advice would be appreciated. I'm not sure if this problem will solve itself when the weight of the full vehicle is put on the spring.
Thanks,
Brandon
Old 04-02-2012, 05:00 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
you should have put the spindle on while compressed .
Old 04-02-2012, 07:17 AM
boatbob2
X2
PUT THE SPINDLE ON,while the spring is compressed,with the weight of the vehicle on the spring,the shock will move to the center,away from the spring.
Old 04-02-2012, 07:27 AM
Last journal entry: My Last Hot Rod
Connect ball joints to spindles
yah can run with out spindles
Old 04-02-2012, 07:53 AM
454 Rattler's Avatar
NEVER SATISFIED !!
Now I'm confused.
454 RATTLER
Old 04-02-2012, 07:56 AM
Wiki Edits: 49
Remove the shock, re-compress the spring and install the spindle. Then reinstall the shock and you won't have a problem.
Centerline
HotRodsAndHemis.com
"It is not always possible to be the best, but it is always possible to improve your own performance. " - Jackie Stewart
Old 04-02-2012, 10:07 AM
Vetteman61's Avatar
Ok, thanks guys. I'll give that a try.
Brandon
Old 04-02-2012, 10:26 AM
shine's Avatar
SPI Thug
i have a hook welded to the side of one of my floor jacks. chain it to the frame and raise the lower a-arm up for spindles.
Old 04-02-2012, 12:17 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
I had to read that a couple of times, while trying to picture it in my head, but I got it now
Old 04-02-2012, 12:26 PM
dirt t's Avatar
spring/shock.
Put a chain under a floor jack , put jack under lower ball joint/a arm put chain over upper ball joint/a arm. SAFTY IS PARAMONT!!! compress spring install spindles all will be fixed.
Old 04-02-2012, 04:57 PM
57halfton's Avatar
Does it look like the top of the spring is seated in the upper spring pocket like it should be ??????? It looks odd to me.
Gene
Old 04-02-2012, 09:25 PM
Vetteman61's Avatar
Well guys, this is what I've got now. The spring is in the same situation with the spindle installed. I can't compress the spring any more with the jack because it simply raises the entire chassis. I still can't get the shock in there because it rubs on inside of the springs. It's almost like the springs are way too long.
Any more ideas?
Thanks,
Brandon
Old 04-03-2012, 06:37 AM
& matts38chev
Gene
I have never done a stock type MII front susp.
should the upper spring seat be farther up into that upper mount?
Old 04-03-2012, 08:58 AM
spacytracy's Avatar
Last journal entry: 1957 Chevrolet 3100 Truck Small Window to Big Window Conversion
Looks like to me you have two issues that may be related. Looks like your spring is upside down. Flattened end of spring should go up in the spring cap, and looks like the spring is not fully up in the spring cap.
Old 04-03-2012, 10:04 AM
Vetteman61's Avatar
Thanks for the suggestions guys. I searched the internet for any kind of a picture of this setup last night for a long time. I came up with an idea that I think is what you have mentioned here. The Chassis Engineering IFS has an adjustable ride height that is adjusted by screwing the top of the spring mount up and down. I was under the impression that mine was as far up as it would go. After finding a picture last night I saw that they can apparently go further up. It turns out mine was just a little stuck and can be screwed up about an inch or an inch and a half. I'm going to try that.
Thanks for mentioning the spring. If it's upside down that would definitely save some room, too.
Thanks guys,
Brandon
Coil over springs and shocks Tim34FSD Suspension - Brakes - Steering 2 12-02-2008 07:38 AM
Coil over springs and shocks Tim34FSD Suspension - Brakes - Steering 0 11-26-2008 02:45 PM
How to pick the right springs/shocks? VolvoGuy Suspension - Brakes - Steering 2 03-18-2006 11:22 PM
New springs/shocks keolab1983 Suspension - Brakes - Steering 2 01-18-2005 11:47 AM
springs and shocks? chevelle327 Transmission - Rearend 0 11-20-2002 06:54 AM
