If you intend to power the rack using a GM pump you'll want to use the standard rack rather than the quick ratio. The GM pump puts out more pressure than the stock Ford pump and unless you use a one of the kits to lower the pump pressure the standard rack will feel like a quick ratio unit. The higher pressure of the GM pump will make it a bit more sensitive so if you use a quick ratio rack you won't be able to relax while driving it. For a street rod you don't need a quick ratio rack anyway.
