Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mustang II steering question
Old 01-16-2010, 09:55 AM
Centerline Centerline is offline
Wiki Edits: 49
No matter which one you buy make sure you get the correct fittings. If you pick one up at Auto Zone or one of the auto parts stores you'll probably get either a Ford built rack or a TRW built rack (Ford used both) and the hose fittings on these are not interchangeable. There are aftermarket hose kits for them but you need to know who made it first. There are a couple aftermarket rack manufacturers as well but I have no idea what size fittings they use.
