Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mustang II suspension on 37' Roadmaster?
  #16 (permalink)
Old 09-08-2011, 10:20 PM
enjenjo enjenjo is offline
Originally Posted by Mutt's37Buick
I understand the midsize GM calipers have more surface area and better stopping tham the GM metric. Found that I cannot buy the Heidts Mustang II with midsize GM calipers and 5 x 4.5" bp. This seemed like a logical combination to allow using a Ford rear end and Ford wheel pattern all around. What are the common solutions to this problem?
Thanks
If you are talking a GM metric rotor, No Limit Engineering has a dual pattern rotor for that with 4 1/2, or 4 3/4 bolt pattern. They also have a 2" drop Mustang spindle that has the GM caliper bracket incorporated into it, and uses all GM metric parts, rotor, caliper, and hardware. Speedway has a large bore metric caliper that is the functional equivalent of the large GM caliper.
