mustang ii suspension on a 38 plymouth - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-04-2012, 10:06 PM
General Martok's Avatar
wow
I love the color on the back part.
suggestion that may help I have a set of laser levels with a 20+foot
dot with cross hatch,I use them for beam to beam level.
I can set them level on the floor and take very accurate measurements with in 1/8 easy beyond 20ft to much diffusion of the laser light.
Your frame looks very ridged whats the mule that your going to put in.
  #17 (permalink)
Old 03-05-2012, 05:14 AM
Originally Posted by matts37chev
i am not sure i understand whats going on here
in the second pic - is the crossmember going to be where it is shown?
or will you cut it on the lines drawn with the marker?
in the pic with the tape, are you planning on cutting the frame off, at the top of the tape line?
by the way, where in wa are you
Yes, the crossmember is (according to the instructions) where it is going to be. The lines on crossmember are just for reference at first I wasn't how far down I needed to cut. Yes, the top of the tape line is where I would need to cut for clearance. I need to be about 9" to the top of the hat from the center of the lower a-arm.
I live in Wapato just south of Yakima.
  #18 (permalink)
Old 03-05-2012, 05:22 AM
Thanks, well the plan is to drop a 350 small block. As they say this is going to be a true backyard build so far I've done all the work from body work to paint after the suspension & the engine I will start the upholstery the plan to is to do every thing
  #19 (permalink)
Old 03-05-2012, 08:10 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
I think I would take off the dropped spindles and move the crossmember up
that way you would not have to cut so much off of the top for the upper pieces
  #20 (permalink)
Old 03-05-2012, 08:34 PM
Thanks for the tip. Are you heading to the Portland swap meet next month?
  #21 (permalink)
Old 03-05-2012, 08:42 PM
I don't understand?
i think so
  #22 (permalink)
Old 03-05-2012, 10:21 PM
Just some pictures of some progress I have made. I started it last August.
ID:	63748   Click image for larger version
ID:	63750   Click image for larger version
  #23 (permalink)
Old 04-08-2012, 06:58 PM
After a lot of homework I found some pictures that show exactly what I'm trying to do. I made some box plates out of angled steel for the bottom. Now the crossmember will have something to weld to. I'm also going with stock spindles instead of the 2" dropped ones I had. I still have to cut and box the top for the upper arms.
ID:	64647   Click image for larger version
ID:	64648   Click image for larger version
  #24 (permalink)
Old 04-08-2012, 08:58 PM
I have done several Mustang installs on that era Mopar, looks like you are on the right track.
  #25 (permalink)
Old 04-17-2012, 07:50 PM
Getting closer I have the top hats fitted & ready to weld.
Name:	mustang ii suspension 003.JPG
ID:	64785   Click image for larger version
Name:	mustang ii suspension 005.JPG
  #26 (permalink)
Old 04-18-2012, 03:25 PM
Very good job Azteca, my name is Mariano and I'm from Argentina. I'm trying to adapt the front suspension of a Chevy (there is the nova), in a Ford 38 standard and your progress give me lots of ideas. thanks
  #27 (permalink)
Old 04-18-2012, 05:32 PM
Glad I could help Mariano. I spent a lot of time trying to figure this out. I will keep posting pictures as I complete this.
  #28 (permalink)
Old 04-21-2012, 08:54 PM
Here's some more pictures
Name:	backyard bombs 007.JPG
ID:	64899   Click image for larger version
Name:	backyard bombs 004.JPG
ID:	64900   Click image for larger version
Name:	backyard bombs 002.JPG
  #29 (permalink)
Old 08-25-2012, 10:18 PM
here is some updates on my build.
ID:	67623   Click image for larger version
Name:	rolling chassis4.png
ID:	67624   Click image for larger version
  #30 (permalink)
Old 08-26-2012, 07:52 AM
Wiki Edits: 27
suspension swap
My son has a 36 Ply coupe, I have 4 SBC in the shop and now he wants to install Mopar power. We have a couple stock MII suspensions, He has looked at a couple Mopars with M II suspensions,
For good instructions go the the Welder Series Site, they have excellent instructions They make weld it yourself parts, M II included and show how to install pieces in about any car proper fitting, alignment, etc.
35 Plymouth Coupe Steering / Suspension new2PlyHR Suspension - Brakes - Steering 6 03-16-2012 10:32 PM
1934 Plymouth front suspension help mopar_madness Suspension - Brakes - Steering 8 05-26-2009 04:06 AM
48 Plymouth Front Suspension Darrell Dorman Jr Suspension - Brakes - Steering 5 08-15-2006 07:10 AM
1956 Plymouth Plaza suspension polkat Suspension - Brakes - Steering 2 03-12-2006 12:39 AM
38 plymouth frame/suspension tcn Suspension - Brakes - Steering 3 11-30-2002 05:48 AM
