Mustang II suspensions
I'll give you my 2 cents BUT remember I'm just giving you the info I've received second hand (translation : I have no first hand experience here ). Mustang II / Pinto front suspensions seem to be pretty easy to adapt to many cars & trucks. For an older car you get disc brakes, rack & pinion steering and a better ride all in one. Some people say that they are too weak for some applications. The biggest reason you hear so much about M II suspensions is all the aftermarket parts available. Pick up any rodding magazine and you'll see everybody has parts. Do a search on this forum and you'll find pages and pages info.
You are correct, sir................ They are from the mid 70s Mustangs. They are popular beacuse they are easy to install. and there are many aftermarket suppliers that make parts for them, like "A" frames and brakes. They are getting harder to find now, because they have been all gerabbed up at the wrecking yards. You might end up buying all aftermarket units.
Ontario Rodders |
From what I have heard,its the simplest system to adapt to a widest array of wheelbase widths. That being said, you can adjust the rack position to eliminate/reduce bump steer.
Most street rods will use what is called Mustang II suspension. Most of the time that means Mustang II geometry. They will use a Heitd's front end for example. This Heidts front end is built on Mustang II geometry. The front end will have tubular "A" arms and coil over shocks with either a Pinto or Mustang II rack and pinion steering.
Some rodders will adapt an original Mustang II front end to their cars, but IMO it always looks like &^%$. The Heidt's or sililiar front end offers a cleaner more high tech front end. Vince |
Even though as a car, the Ford Mustang II was a total abortion, it has some parts that adapt to street rodding amazingly well. The real beauty of it and the Pinto is that they are semi-compact size which matches the size of pre-war autos perfectly. MII auto tranny shifters, emergency brake handles, rear ends, air conditioning systems, all fit right into classic street rods perfectly. But the front suspension is the most highly prized donation to the street rod community. The old straight axle was the standard (and still is for that matter), but as street rodding evolved, upgrading technology became more important. Add to that the explosion of building cars to drive long distances not just to the drag strip on Friday nights, and the desirability of a nice ride becomes apparent. The street rod community was actively searching for a good independent front suspension donor for years before the MII came out. Corvair and various Chrysler compact car torsion bar front suspensions were used with moderate success. Nothing really fit or looked well in the application.
Then the MII/Pinto platform came out had there was as very compact, perfectly sized suspension that would graft seamlessly onto an old buggy frame and give the prefect ride that everyone was searching for. Although the stock X-member gets a lot of bad press for looking ugly, if properly installed it can easily be made into a show winner. Add to that the compact and efficient manual and power rack & pinion steering gear and this became the no-brainer choice for suspension upgrade. There is nothing out there that even comes close. This is exactly how it comes out of the donor car. Looks pretty nice even in this grungy condition! I post this picture in threads like this often but this is the stock unit installed in a multi-award winning Willys pickup,
| How to properly mate a GM pump to a Mustang II rack | Centerline | Suspension - Brakes - Steering | 73 | 10-31-2009 11:59 AM |
| Mustang II bump steer, drifting | Chev283 | Suspension - Brakes - Steering | 2 | 06-19-2004 08:15 PM |
| Are Mustang II Crossmembers Safe? | Jon | Suspension - Brakes - Steering | 14 | 10-17-2003 12:43 PM |
| Mustang II suspention? | Nos | Suspension - Brakes - Steering | 8 | 04-22-2003 03:01 AM |
| alternative to MUSTANG II suspention | norms37chevy | Suspension - Brakes - Steering | 6 | 01-31-2002 11:48 PM |
