Mustang II tierod ends - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2011, 04:32 PM
Need some longer tierod ends for my Mustang II Rack (only need 1 inch both ends. Have heard that Ford Fairmount tierods will do. Any suggestions
Old 11-24-2011, 05:38 PM
Cape Cod Bob's Avatar
Fairmount ends are what I have on my SR. My x member is 4" wider then stock. What is the app.
Old 11-24-2011, 06:57 PM
More info please:
I am rebuilding a 54 Ford P/U. I will post pictures later. This truck is a present for my wife. So I will go out and get Fairmount Tieend. Do I need a certain year.
oldman w/white 57. My pride and joy is my white 57 Chevy 2dr Hardtop, and yes I am an old man.
I like your ride. Enjoy it
PS: what does S/R mean
Old 11-24-2011, 07:18 PM
Originally Posted by oldman w/white 57
More info please:
First off, no you're not older then me 65
sr= street rod
not sure of the year but probably all will work. Available at Summit or speedway for sure'
I would try NAPA online first. Then go pcup'
I wish I had a 54 picup to do.
Thanks for the compliment on my ride. Had 'er out today for a coffee run. I really like stompin' it. I really feel it going into 2nd(th350) as I put in stronger springs.
My Dad had 57 fairlane with a 312 4bbl and fx tranny. Made the 409 chevies think a little.
My sister had a 57 2dr chevy with a 283 power pack. That really hauled. Course that was in the mid 60's.
Told u I was older then dirt didn't I?
Old 11-24-2011, 07:25 PM
I went thru GA last spring on my way back from FL and took the scenic route from Moody military base and saw a lot of old iron. Must be great to be so close to that iron. Stuff up here is rare and all rotted out.
Old 11-24-2011, 08:52 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Back when UAP/NAPA (Canada) sold Moog chassis parts, I recal that we had a specifications book that had tie-rod ends by dimensions. We're back into the NCP (NAPA Chassis or Perfect Circle / Spicer) now, and I'm not sure that such a catalog even exists anymore.
I can give you the dimensions for a specific application / part number combination, however.
Here is your 1978 Ford Fairmont.
NCP #269-2457
Attributes
Overall Length (Dimension D) : 11.09"
Rack End Thread (Dimension A) : .938" - 20
Socket Length (Dimension C) : 1.64"
Type : 1
#269-2535
Attributes
Large Diameter Taper (Dimension B) : .63"
Length (Dimension F) : 5.08"
Right or Left Hand Threads : RH
Rod End Thread (Dimension A) : .562" - 18
Small Diameter Taper (Dimension C) : .55"
Stud Thread Size (Dimension E) : .5" - 20
Taper Length (Dimension D) : .58"
Thread Type : Male
All of the refernces seem to idicate that this information MUST have come from a referenced drawing in the specifications book.
Hope this helps
Old 11-25-2011, 10:13 AM
Tie rod ends
Mid 80's Thunderbird are longer than mustang by over an inch.
mustang II front ends trevb146 Suspension - Brakes - Steering 3 06-06-2011 11:09 PM
mustang odds and ends Knight_Mare Interior 4 05-02-2009 05:58 AM
pinto/mustang II tierod dave377 Suspension - Brakes - Steering 5 10-29-2007 03:42 PM
Mustang front ends........... poncho62 Suspension - Brakes - Steering 11 02-02-2007 10:35 PM
rod ends dartcc Suspension - Brakes - Steering 3 05-06-2003 09:42 PM
