-   -   Mustang ll Suspension Measurements (http://www.hotrodders.com/forum/mustang-ll-suspension-measurements-26979.html)
Wayne Rogers 10-31-2003 01:34 PM
I need the original Mustang ll suspension measurements, not the set-up numbers, but the actual pick-up points, ball joint centers and spindle height and degree angle of the spindle. Considering how popular this design is, it should be pretty easy to locate, but I can't find it anywhere. A scale drawing or something similar would be super.
Thanks,
Wayne Rogers
Gilroy, CA
waynedreves 05-30-2004 11:44 AM
Mustang ll measurements
Have you found any info on the Mustang ll suspension measurements or drawings?
I am also interested in building a Mustang ll setup.
deuce_454 06-01-2004 05:03 AM
i have a mustang 2 crossmember, what measurements do you need?? angles??, i could do an autocad drawing and e-mail it, but im not going to do it unless someone is really interested, or it would be wasted effort..
charlesjonas 06-02-2004 10:06 AM
I for 1 would like to have a autocad of the mustang II. I made a coilover suspension out of a mII but it will look better if i had the cad to do 1 out of mild steel. thanks cj
deuce_454 06-02-2004 10:52 AM
damn... :thumbup: i was hoping no one replied.... :rolleyes:
charlesjonas 06-03-2004 05:25 AM
Any and all help will be appreciated. thanks cj
Phil1934 06-08-2004 03:32 AM
Join http://groups.msn.com/ZekesHAMBerChat There's a how to article in the tech section to make a M II.
charlesjonas 06-08-2004 10:33 AM
Thanks. I am a member of the hamberchat and have TRIED to pull up yhe file but it is not readable. I am going to try a 2nd computer. cj
