Mustang ll Suspension Measurements - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2003, 01:34 PM
I need the original Mustang ll suspension measurements, not the set-up numbers, but the actual pick-up points, ball joint centers and spindle height and degree angle of the spindle. Considering how popular this design is, it should be pretty easy to locate, but I can't find it anywhere. A scale drawing or something similar would be super.
Thanks,
Wayne Rogers
Gilroy, CA
Old 05-30-2004, 11:44 AM
Mustang ll measurements
Have you found any info on the Mustang ll suspension measurements or drawings?
I am also interested in building a Mustang ll setup.
Old 06-01-2004, 05:03 AM
deuce_454's Avatar
i have a mustang 2 crossmember, what measurements do you need?? angles??, i could do an autocad drawing and e-mail it, but im not going to do it unless someone is really interested, or it would be wasted effort..
Old 06-02-2004, 10:06 AM
New Member
I for 1 would like to have a autocad of the mustang II. I made a coilover suspension out of a mII but it will look better if i had the cad to do 1 out of mild steel. thanks cj
Old 06-02-2004, 10:52 AM
deuce_454's Avatar
damn... i was hoping no one replied....
Old 06-03-2004, 05:25 AM
New Member
Any and all help will be appreciated. thanks cj
Old 06-08-2004, 03:32 AM
New Member
Join http://groups.msn.com/ZekesHAMBerChat There's a how to article in the tech section to make a M II.
Old 06-08-2004, 10:33 AM
New Member
Thanks. I am a member of the hamberchat and have TRIED to pull up yhe file but it is not readable. I am going to try a 2nd computer. cj
