mustang master cylinder
i have an 89 mustang that im using for a drag car and the cam im using doesnt allow me to run power brakes what standard master cylinder would be best to use the rest of my brake setup is stock thank you
how
how would the cam affect a vacuum hose on the intake?
with a big cam, they dont create the vacuum needed for power brakes.
i wouldnt want to delete the booster, i would run a vacuum pump soly for the booster. if you really want the booster gone, grab a wilwood master. |
manual brake master from any fox body fron 79 up should work fine.Use the manual brake position on the brake pedal for the rod.
| All times are GMT -6. The time now is 04:35 PM. |
