mustang master cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2009, 12:07 AM
i have an 89 mustang that im using for a drag car and the cam im using doesnt allow me to run power brakes what standard master cylinder would be best to use the rest of my brake setup is stock thank you
Old 05-28-2009, 05:38 PM
68MercCougar's Avatar
how
how would the cam affect a vacuum hose on the intake?
Old 05-29-2009, 01:54 AM
machinist & fabricator
with a big cam, they dont create the vacuum needed for power brakes.
i wouldnt want to delete the booster, i would run a vacuum pump soly for the booster.
if you really want the booster gone, grab a wilwood master.
Old 05-29-2009, 05:29 AM
manual brake master from any fox body fron 79 up should work fine.Use the manual brake position on the brake pedal for the rod.
using only the master cylinder and takin out the break booster Arillious Suspension - Brakes - Steering 12 08-14-2007 11:02 AM
What type of Master Cylinder 49dream Suspension - Brakes - Steering 5 01-17-2006 06:05 PM
Master cylinder sizing, dumb question? baddbob Suspension - Brakes - Steering 6 06-19-2005 01:02 PM
Stang master cylinder Old Crow Suspension - Brakes - Steering 3 06-10-2002 12:40 PM
