Mustang/Pinto Rotors on Early Ford Spindles - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2006, 07:55 AM
NAIRB's Avatar
Does anyone have any knowledge if this is/has been a common swap in the past.
I work for Speedway, and we don't offer any kits in that configuration. I am talking about 37-48 spindles.
If anyone has any information on what it takes to get this done, please let me know.
Nairb
Old 11-26-2006, 05:02 PM
With the Mustang II/Pintos having a 4 lug wheel ... I doubt if this has been a high swap over priority ...
Old 11-26-2006, 05:36 PM
BOBCRMAN@aol.com's Avatar
I have used the Pinto/Must II rotors and also Ranger/Granada rotors. I make up a spacer/adapter to fit the old ford spindle. Spacer is about 1" long. bored out to fit over the spindle/axle shaft. Counter bored a bit so it fits tight against the shoulder of the spindle. I try to make the inner bore about a .001" press fit and the outer surface is turned for a std Ford Pinto seal and inner wheel bearing race.
Then I turn down the outer part of the axle (threaded). To fit a Ford outer wheel bearing. The threaded portion has to be threaded more as the hub is narrower than the old stuff. Then mount new hub. mark a cut off spot and shorten orig spindle. Use a cutoff wheel to extend the groove and re drill a cotter pin hole.
In the good old days I used to take the old junk Pinto rotors. Knock the rotor part off. Turn down the OD. Redrill for 5 bolt and use modified VW type II rotors and calipers. 3/8" flat plate brackets. (Have a set on the "T" bucket now.
For spacer material I have used mild steel and I have used discarded old bearings from the bucket beside my press. As long as the dimensions are correct and the bearings fit snug on the adapters. Away you go!!!
Nowdays I try to use aftermkt calipers, or some BMW with a Granada spindle/rotor.
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 01:15 AM
early ford torque tube broaddua Transmission - Rearend 2 11-20-2002 06:57 AM
coilovers on early ford beetle9 Suspension - Brakes - Steering 2 11-05-2002 08:35 AM
Ford Race Engine BarbWire Engine 7 10-18-2002 12:38 PM
Selling a mid 60s, early 70s Ford 8" bildo95 Transmission - Rearend 2 08-19-2002 01:12 PM
