Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mustang/pinto suspension on a model A
Old 03-28-2002, 05:24 AM
Don Meyer's Avatar
Don Meyer Don Meyer is offline
Post
You can get a universal kit from Heihts or weld the original Must crossmember to your frame. I have done 3 Model A's this way & one w/a Heights crossmember. I feel that using the stock crossmember is easier once it is cleaned up. mount it at a 3 degree angle(positive castor) & mount it so that the rack has just enough clearance where it passes under the frame.
As far as the fenders a bubble will have to be added to the fenders so the upper A arms clear. I make the bubble the full length of the fender so it is not as noticable.....I have some digital pictures I can post if someone can give me directions on how to do it.......Don
[ March 29, 2002: Message edited by: Don Meyer ]</p>
