Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mustang/pinto suspension on a model A
Old 04-03-2002, 06:26 PM
hotrod_tommy hotrod_tommy is offline
good stuff. Budget cars really piss off the big kids, coz you have as much fun for less $$$.
I have done several MII fronts, even used most of the stock crossmember on a couple before I made my own "kit"
There are several rods around with fender lumps. just think smooth and don't just weld in a square-cornered box. Looks okay.
heck, some cars have humps for steering or spring mounts, etc... just try to make it flow with the lines, you're there.
Fat man and groundhawg (Sp??) have been affordable to some friends - if ya chose not to modify the stock.
I cut off the hats and build plates to mount to the frame and lower crossmember. Depending on your skills and buddies' help avail... only you know what route you can successfully finish.
that's the key.
