Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mustang power rack
Old 07-02-2011, 11:36 PM
aosborn's Avatar
aosborn aosborn is offline
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Typically to be very effective you need to reduce volume and pressure. I use the P/S valve for the same pump from a 4 cylinder car, it has a small orifice. Then adjust the shim pack to reduce spring pressure. That is the inexpensive way to go.
Andy
