Mustang power rack - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2011, 10:51 PM
nitrus02's Avatar
Mustang power rack
I am using a pinto suspension, a chevy power steering pump, and a 94 Mustang steering rack. I wanted to know if I need to use a volume reducer in the newer mustang rack?
I've read post saying that you need to use one on mustang 2 rack but nothing on newer racks.
The reason for using the 94 rack is because it was free and it was wider so I didn't need to expend it to work. Just need to know I need a volume reducer?
Thanks
Old 06-30-2011, 01:15 PM
slow4dr's Avatar
Yes, you will need to reduce the pressure. Free isn't always a good thing, if the geometry isn't right your safety will be compromised.
-J
Old 06-30-2011, 05:17 PM
nitrus02's Avatar
The rack works perfectly in the truck just needed to know if I need to reduce the pressure before I do any damage to the seals. I'm always concerned with safety the main reason for using it is because its the perfect size.
Old 06-30-2011, 05:42 PM
nitrus02's Avatar
What reducer should I use? Do you have a part#? I have a 1982 chevy 350.
Old 07-01-2011, 09:13 AM
slow4dr's Avatar
I would run the adjustable one that Heidt's sells.
-J
Old 07-01-2011, 08:32 PM
Cape Cod Bob's Avatar
I tried shims and some have good luck but mine is still to loose so if I were you I would go with the reducer.
Old 07-02-2011, 08:59 AM
3rdmember
guys, volume and pressure are 2 different things...
Old 07-02-2011, 08:11 PM
Absolu tly correct. And how does that knowledge help answer his question. Please explain, Bob.
Old 07-02-2011, 08:33 PM
3rdmember
well, is he trying to reduce pressure OR volume?
my GUESS would be pressure but i could be wrong
if it's pressure, don't get to excited, i've ran my MII rack (used) for many miles with a run-of-the-mill gm (not for r&p) pump.
if you're REALLY worried, grap a pump off an early omni (remember those POS?) or a mopar FWD wih a saginaw pump and use it....
some of you guys really make stuff complicated....
Old 07-02-2011, 09:17 PM
After rereading the original post I see he refers to volumn. I'm pretty sure he means pressure as the gm pump puts out I think over 1000 lbs. pressure and the MII rack needs less around 8-900 lbs . Don't qoute me on exact #'s. A search on this forum will turn up a lot of info as this has been discussed many times.
Old 07-02-2011, 11:36 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Typically to be very effective you need to reduce volume and pressure. I use the P/S valve for the same pump from a 4 cylinder car, it has a small orifice. Then adjust the shim pack to reduce spring pressure. That is the inexpensive way to go.
Andy
Old 07-26-2011, 02:21 PM
pnt4u2's Avatar
Flow Control valve needed
What is needed to connect a GM p/s pump, rated at 3gpm, to a Mustang II rack, using 2 gpm, is a flow control valve. Speedway Motors has them, under $20, when I bought mine. It screws into the back of the p/s pump, replacing the control valve already in use. I have a the same set up and it cured my problem. Problem known as the "twitch" commonly caused by mating a GM pump to a Ford rack.
Rake look drhardwood Suspension - Brakes - Steering 2 04-23-2011 07:07 AM
Stance & Rake - How Much? ant_8u General Rodding Tech 19 01-23-2011 01:48 PM
Hoods, trim and rake LimitedKnowledge Body - Exterior 0 09-06-2004 07:28 PM
ladder bars to get more rake camino_man Suspension - Brakes - Steering 1 02-29-2004 02:43 PM
Setting my rake Maverick Suspension - Brakes - Steering 1 06-21-2002 01:43 PM
