mustang rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2011, 08:18 AM
mustang rear end
would like to up grade to 5 lug wheels on a 66 mustang rear end.does anyone know if ford ranger axles would work.if so what years would fit
Old 06-29-2011, 08:59 AM
Irelands child's Avatar
Some of these 6 cylinder Mustangs had the tried and true 8" rear end even with the 4 lug axles. If so, remove the old axles and brakes and install a donor version from a V8 or possibly any Maverick/Comet. Then some Mustangs had that dinky remove the back cover 'C' clip unit. BUT - it would be much, much easier to find a complete 8" rear end and bolt in place then to fool with Ranger axles which most likely are too wide and probably will not work.
Irelands child
Old 06-29-2011, 09:59 AM
For 5 lugs, you will need custom axles.
Try Dutchman or Moser.
You might find a small bearing cut-to-fit axle so measure your existing axles and check with Randys.
Old 06-29-2011, 10:30 AM
prostreet6t9's Avatar
Differential/Driveline
If you have a 8" diff you might check randy's.They have a cut to fit axle for those.
Old 06-29-2011, 11:58 AM
JeffB's Avatar
Contact Arizona Muscle Mart it is an all Mustang salvage and restoration business 1(602)233-0616
67 Mustang rear end mtgmustang Transmission - Rearend 4 03-14-2007 06:19 AM
66 mustang rear end gun70runner Transmission - Rearend 1 02-18-2006 05:53 PM
5.0 Mustang rear end beach10222 Transmission - Rearend 0 01-27-2006 08:57 PM
mustang rear end Stangman196700 Transmission - Rearend 0 02-16-2004 03:53 PM
mustang rear end,,help chrislana Transmission - Rearend 1 06-07-2003 08:59 PM
