Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mustang stalling out of the blue
Old 02-12-2009, 06:58 AM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
Pretty small amount of info to go on, have you checked the fuel level in the bowls?? That should affect it in both directions, but since you never stated what you had checked, I thought I would start there.Center pivot floats aren't as likely to have an issue like this as the side pivot ones. There shouldn't be any electrical piece that is in the area of the steering, but you might also check the wiring around the coil and to the dist. The wires become brittle over time and it's possible that in the one direction a wire is losing continuity. From your basic description it sounds fuel related though. Maybe the fuel pick up in the tank is getting something drawn into it many things and no list of what you may have checked.
