Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mustang stalling out of the blue
Old 02-12-2009, 12:34 PM
gcanavy gcanavy is offline
well Im not sure what happened but for some reason now its not doing it anymore. I did check all the grounds they were good. i did lower the bowl hight a little, so ill have to keep messing with that. The gas take is full, so im not sure how the gas sloshing from one side to the other would make a difference. I did put some heat into the gas to absorb whatever little bit of water that might be in there. All fuel lines are clear of any stearing components so nothing is getting pinched. This year in fact does have that wiring harness that runs right along the radiator support, so i could see that becoming a problem. ill have to try that clear fuel filter. thanks for all the help.
