mustang steering options? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2005, 06:14 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
Starting a project (28 ford sedan) that has a older TCI frame with the mustang (65 I'm told) steering box in place. The column is very upright, and a little tall (we intend to chop the top), so we are thinking of changing something. Our first thought is a Tilt column. Don't want big and bulky. Is there a later mustang box with tilt column that will bolt in? Has anyone cut the column and case and put in a joint to make a fixed angle? Any suggestions? Thanks
Old 09-20-2005, 08:11 PM
30desoto's Avatar
Dodge ain't all bad
oldguy829
There are a number of ways to go on your project,
You could go to a flaming river tilt column with rack and pinion steering
You can change your steering column by cutting it down and making it smaller and build special mounts and a shorter shaft w/ joints to go through the fire wall and adapt your mustang steering box or replace it with similar style from chevy ford or corvair, or adapt it for rack and pinion steering.
There are numerous ways to go on this does your 28 have a straight front axel or independent front suspension is there room in the cab to angle the steering column with a change of seat placement, if I keep going there could be hundreds of questions and answers. are you good a fabrication or not bad and can fab some items? Picture will also help with answering your questions. There are alot of people on this board that can help so please give us all a chance.
and welcome to the board
30dee
Old 09-21-2005, 04:49 PM
oldguy829's Avatar
Wiki Edits: 88
Thanks, obviously I got ahead of myself here. I need to regroup, take some pictures, list all the things I want to do and see how they fit together.
I'll be back.
Old 09-21-2005, 07:01 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
OK, The 30 Ford Coupe in my Avatar has a 67 Mustang steering box, I connected it to a Camaro tilt column, it works great. I chopped my top 4 inches. The coupling that I used to connect the column to the box has a U-joint in it so that allows you to mount the column at any angle that you want. I fabbed my own column mount.
Old 09-22-2005, 04:48 PM
oldguy829's Avatar
Wiki Edits: 88
mustang steering options.
Henry, sounds like exactly what I want. Can you PM me with pictures and more details, like year/model column etc. Nice that you have a 30. Everyone tells me 32 and up is the way to go. Too many issues with the old ones. But here we are.
Started disassembly today and I have a bunch of quesitons already, starting with matching the body to the frame, but I'll put it in the proper forum. Check it out if you get a chance.
Oldguy829 pm at = djw829@sbcglobal.net
Old 09-22-2005, 06:11 PM
Lost in the 60's
Wiki Edits: 4
OK, It does not mater what model..any Camaro or Firebird column will be the right length. I coupled the column to the Mustang box with a U-joint that was splined on one end to fit the Mustang box and had the Double D on the other end to fit the GM column. I got the coupler joint from Borgeson Universal Co. I am E-mailing you some pics. Hope this helps.
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 12:59 PM
Mustang II Power Steering Rack Dave42 Suspension - Brakes - Steering 7 02-13-2006 06:26 PM
Mustang II IFS Steering Adjustment horvath Suspension - Brakes - Steering 14 05-09-2004 12:25 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
Need Help Setting Up Mustang II Power Steering hammondben Suspension - Brakes - Steering 4 02-26-2003 06:15 AM
