Mustang Super Shifters - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2006, 09:56 AM
Anyone out there running old school Toploaders with Hurst Supershifters?
If so, how did you modify trans tunnel brace to clear shift rods?
Thanks - Gydyup
Old 12-16-2006, 01:07 PM
larryblack's Avatar
Certified Lead Foot
I used a couple of super shifters and usually a heat wrench worked just fine to enlarge the hole to clear the linkage.
Mount the tranny, mark a small area and cut. Today there are plenty of roto zip type cutters that would cut cleanly. After the hole was made to accomodate the linkage, new sheet metal was installed around the linkage to cover things up.
The super shifter boot will mold to most floors well enough.
Stock consoles will not work with out extensive modifications. The shifter sits quite a bit to the left.
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Street Legal TV to Broadcast Video from NMCA Super Bowl Event at Route 66 nmrajames Hotrodders' Lounge 0 07-26-2006 09:53 PM
Will a 390 fit or work in a 73 Mustang..... onebadmerc Engine 4 12-08-2005 09:57 AM
BW (super?) t-10 swap for '80s mustang 5sp ChevelleSS_LS6 Transmission - Rearend 1 11-02-2004 06:56 PM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
