Mustang T5 Speedo cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2009, 03:48 PM
Last journal entry: A/C compressor braket continued
I have a '84 Ford T5 and a GM "standard" sending unit for an electronic speedometer.
I am not all that familiar with Ford stuff and I was surprised to see that the speedo gear is part of the cable. Do the electronic sending units for Fords come with the gear or with provisions for mounting the gear?
The photos (I hope there are photos) show the cable next to the tranny and the sending unit I have.
Is there a way to make my sending unit work with this tranny?
Thanks
Dan
Name:	speedo cable.jpg
ID:	42332   Click image for larger version
Old 12-03-2009, 05:48 PM
tnsmith10's Avatar
when will it rain???
Thanks
Dan
theres a little black clip that holds the gear on. the ford v.s.s. has the same mounting for the gear.
the v.s.s. is a 2 wire plug and the pigtails are available through the dealer.
just get a v.s.s. for a later model mustang with a t-5 manual, id say 88-89 would be ideal. gl
Old 12-03-2009, 07:58 PM
That sounds like a simple solution, Thanks for the info.
mustang t5 to chevy 350 leftoverchrisac Transmission - Rearend 2 03-18-2004 10:25 AM
Speedo not working..4spd Trav Transmission - Rearend 5 07-31-2003 01:21 AM
