Mustang Tranmissions - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2006, 02:16 PM
Which way to go, I am going to swap out my C4 for a manual - problem being there are too many options?
Car is a 67 Mustang with a 351W, Hyd Roller, RPM Heads, Performer Intake.
Rear is a 9" with a 4:56 spool - running Hi 11s low 12s
Putting the car back on the street, and I just like to stir my own soup - just wonder what others have found works. Intend to still thrash the car on the track from time to time, but mostly do local cruises and rumble around the hood - no highway stuff.
Whats working best, Richmond, Tremec T5 or sticking with the toploader. Recognizing the first two will require lossing the 4:56.
Big question - what clutch systems are best - I would like to avoid the old mechanical z bars etc - sounds like the JMC hydraulic is a good idea? Does it work with any of the three transmissions above?
Thanks Gydyup!
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 12:59 PM
Will a 390 fit or work in a 73 Mustang..... onebadmerc Engine 4 12-08-2005 10:57 AM
04 mustang rust oldred Body - Exterior 3 07-19-2005 08:15 AM
Mustang II bump steer, drifting Chev283 Suspension - Brakes - Steering 2 06-19-2004 09:15 PM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 01:43 PM
