Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mustang Transmission
Old 08-12-2006, 09:11 PM
matt167 matt167 is offline
Wiki Edits: 31
Originally Posted by bates_k
Not entirely true, the trans will work, the bell housing wont,
you'll need a bell from a V8, which the tranny will bolt to, you
may need another torque converter, or at least an adapter
made to locate the present TC in the V8 crank...
K
on the small 6 engines, the bell housing is not removable on the auto tranny's, but any 3.03 3spd manual will work with the right bellhousing because they are removable
