-   -   Mustang Transmission (http://www.hotrodders.com/forum/mustang-transmission-95658.html)
StevO8263 08-12-2006 08:06 PM
My mustang has a 200ci straight6 engine in it, I bought a 289 with the transmission that it came with, will the transmission mounts already on my mustang work or do I need to buy different ones, and which ones would i need? thanks, steve
matt167 08-12-2006 08:24 PM
I would reccomend putting anything further in 1 thread, to keep things simple. as I said in annother thread, your C4 automatic will not work with a V8, it's got the wrong bellhousing to work, you need a SBF C4 auto but the trans mount will work
bates_k 08-12-2006 08:31 PM
Not entirely true, the trans will work, the bell housing wont,
you'll need a bell from a V8, which the tranny will bolt to, you
may need another torque converter, or at least an adapter
made to locate the present TC in the V8 crank...
K
StevO8263 08-12-2006 08:40 PM
When i bought my 289 the transmission that was pulled with it i also bought and its still connected, i was just wondering if the mounts would work
matt167 08-12-2006 09:11 PM
K
on the small 6 engines, the bell housing is not removable on the auto tranny's, but any 3.03 3spd manual will work with the right bellhousing because they are removable
Terry Pankow 08-19-2006 11:40 AM
Mustang Trans Match Up
To answer your original question, I have seen many a replacement of a 6Cyl. with a 289/351W. You failed to indicate the year of your Mustang.
Any area you may encounter a problem might in the clearance for the bell housing and the firewall. Later years 289s use a larger bell housing and may cause clearance issues.
The trans cross over shouldn't be any problem in regards to length. Ford used the same C-4 trans on 6 as they did on the 289 with the Mustang. The cross member is the same for all engines/trans combination.
You should use new motor and trans mounts for the 289 and its tranny like you would any rebuild.
