Mustang Transmission
My mustang has a 200ci straight6 engine in it, I bought a 289 with the transmission that it came with, will the transmission mounts already on my mustang work or do I need to buy different ones, and which ones would i need? thanks, steve
I would reccomend putting anything further in 1 thread, to keep things simple. as I said in annother thread, your C4 automatic will not work with a V8, it's got the wrong bellhousing to work, you need a SBF C4 auto but the trans mount will work
When i bought my 289 the transmission that was pulled with it i also bought and its still connected, i was just wondering if the mounts would work
Mustang Trans Match Up
To answer your original question, I have seen many a replacement of a 6Cyl. with a 289/351W. You failed to indicate the year of your Mustang.
Any area you may encounter a problem might in the clearance for the bell housing and the firewall. Later years 289s use a larger bell housing and may cause clearance issues. The trans cross over shouldn't be any problem in regards to length. Ford used the same C-4 trans on 6 as they did on the 289 with the Mustang. The cross member is the same for all engines/trans combination. You should use new motor and trans mounts for the 289 and its tranny like you would any rebuild. |
| C-4 Transmission. (1965 Mustang) | 65Stanger | Transmission - Rearend | 5 | 01-30-2006 07:32 PM |
| Hotrodders Knowledge Base: Transmission - Rearend | Jon | Transmission - Rearend | 0 | 11-26-2005 06:23 PM |
| 1972 Mustang Grande transmission question | demitristewart | Engine | 5 | 07-31-2005 07:27 PM |
| Transmission Information. | M&M CUSTOM | Transmission - Rearend | 1 | 08-24-2004 03:15 PM |
| Mustang transmission | MUSTANG 88 | Engine | 3 | 09-17-2002 03:22 AM |
