Mustang Trim Removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2005, 04:23 PM
Hi, does anyone know how to remove the trim which is painted body color that runs along the side of the windshield and across the top of the door of a 2000 Mustang GT. Thanks
Old 03-19-2005, 04:38 PM
The front piece is held on with screws going up into the roof rail. You get to them by pulling the window rubber seal down. It fits into a channel and comes off easy. As I remember there are some clips of some sort that hold the top. You remove the screws and then lift up and it comes off.
The rear piece is bolted on and you have to remove the interior quarter trim. Behind that you will see long studs with nuts sticking in. You have to go thru holes in the inner structure with an extension and deep socket.
I think there is one screw at the top in the front after the front piece is removed also, but you would see that if it is there, pretty self explainatory.
DO NOT FORCE THESE PARTS. They come off very easily once all the screws and nuts are removed.
Old 03-19-2005, 05:29 PM
Thanks, I found some clips but could not find anything near the roof. I'll pull the rubber down now. I was afraid to force because it feels pretty weak and I don't want to break it.
Chrome trim removal on 73 Mustang.... onebadmerc Body - Exterior 3 03-18-2005 08:01 AM
1985 Monte Carlo Windshield trim and rear windshied trim removal ChrisMiddleron Body - Exterior 3 01-14-2005 06:20 AM
Mustang II upper A arm removal RodFather Suspension - Brakes - Steering 4 08-30-2004 01:52 PM
Mustang II bushing removal 41ChevCoupe Suspension - Brakes - Steering 17 09-21-2003 02:54 PM
'59 Ford/Edsel trim removal? kevkoracing Body - Exterior 1 08-24-2003 07:24 AM
