mustang2 crossmember critique - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2005, 07:00 PM
moparx's Avatar
New Member
please view attachment & give your opinion on the crossmember i built for my 33 dodge "humpback" panel. it is constructed of 3/16" plate, boxed on all sides. the lower control arm pivot bolt is 5/8"[all-thread is being used now for mockup]. the internal plug is 2 " o.d. , fully welded around circumference. the external plugs are 1 3/4" o.d. as per previous discussions, i am considering adding a top gusset in addition to the side gussets on the external plugs. thank you in advance for your opinions.
Name:	im000865 (small).jpg
Old 01-08-2005, 09:30 PM
adtkart@aol.com
It is kind of hard to tell anything. The photo doesn't show much, except it looks like the upper control arm will hit the frame when it travels down. You might try posting more photos showing more angles and details.
Old 01-09-2005, 03:43 PM
moparx's Avatar
New Member
what other views would be more appropriate for discussion ? the upper arm will hit at approximately 8" drop. i feel this is not a concern, as the coilovers only have a total of 3" of travel. i am thinking of mounting them @ 50%-55% of shaft showing[50% jounce/rebound- 55% jounce-45%rebound]. the mounting angle of the shocks give me approximately 7 1/2" total up & down movement at the wheels. will this be ok ? shocks are aldan eagle adjustables- 13 1/2" extended, 10 1/2" collapsed. mounting angle of shocks is 18* from vertical. lower control arms are level @ ride hight. upper arms have 3* anti-dive angle. the lower arms are 12 1/2" long from pivot point to lower bj. c/l. the upper arms are 8" from pivot point to bj. c/l. the front view swing arm length @ ride hight is 125". i do not know, at this time, the bump curve as the rack has not been mounted. the camber curve goes from +1/8*[at ride height] to -1.5* @ 4" jounce. i have 7.5* caster built in. these specs are with no shims in the upper pivot arm mounts. the upper pivot mounts can be rotated 180* to then start at a -2* camber[ which could be then shimmed to 0]. please advise which angles [pics] would be better to further this discussion. thanks in advance.
Name:	im000866 (small).jpg
Old 01-10-2005, 05:46 PM
You have been busy!!!. I can not tell by the pics if you have gussets on the top plate the upper arm attaches to. Is this the area you are contemplating adding gussets? If so I strongly recommend it. I like the gusset on the lower control arm mounting boss. Did you do all your calculations or did you Japanese engineer the Mustang II? Also, the rise you have on your cross member looks as though your nose is going to be in the air.
How about a close up birds eye view looking straight down on the upper control arm and a quartering rear drivers side view with the wheels turned right.
Trees
Old 01-10-2005, 07:56 PM
moparx's Avatar
New Member
thanks for the reply. as to the upper a arm mount , i have not finished this area with regards to gussets/boxing. also, the upper shock mounts have not been finalized yet. i am working on those now. i have some cardboard cut, and will transfer to plate & see if i accept the outcome. the crossmember has a rise to it because the front frame section has an 8" "z" in it. this will result in a very low stance. my calculations have been arrived at by some suspension books i have purchased, as well as inspecting 4 different mustang2 installations. i did not like some of ways the lower arms were attached, or the strengthening of the crossmember in these kits, this is why i used the 2" & 1 3/4" dia. material for the lower arm mounting plugs. i will take a couple of pics tomarrow of the views you suggest. the gusset i was refering to[adding] in the previous reply, was as is shown on the lower control arm mounting boss, but pointing upward[toward the upper control arm] in the middle of the crossmember. would this be an acceptable strength increase, or a waste of time ? thank you again for your assistance with my project.
Old 01-11-2005, 07:06 PM
moparx's Avatar
New Member
here is a view from the top. i got sidetracked & forgot to get a rear view. i'll get one tomarrow. tree, didn't you have a problem with a lower bolt shearing off ? was this caused by a cheap bolt , or no lube on the bolt inside the lower pivot plug inside the crossmember ? thanks in advance.
Name:	im000871 (small).jpg
