MustangII Frame Stance for IFS install??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2006, 01:57 PM
DV8's Avatar
DV8 DV8 is offline
Sloe Lurner
Last journal entry: front boxing plates
I know I've read somewhere here before, somebody has asked about the setup for the front crossmember as it pertains to ride stance. I'm about ready to weld in my TCI front crossmember and I would like a little help from my fellow rodders. Is there a proper stance meaning the difference from front to rear, is it personal preferance? I am also installing the 4 link rear end. I would like to use all 4 tires of the same size. keep the truck fairly level but still have a little attitude. When welding in the front crossmember it needs to be parallel to the ground. Can i get some feedback about where i should start.
Old 09-27-2006, 05:41 PM
DV8's Avatar
DV8 DV8 is offline
Sloe Lurner
Frame Rake....
And looking more I found what I was looking for using the term "rake" Thanks Centerline.....again. I'll use 2 inches. Just for everybodys FYI I called TCI also and while talking to them the tech told me if I wanted the stock height spindles they would swap the 2 inch drop spindles i have for me...We'll see how that goes...All i have to pay for is the shipping...$
Front clips and frame swaps --- More work, less value Centerline Suspension - Brakes - Steering 23 05-25-2005 09:42 PM
Installing frame ties on GM uni-bodies twa14 Suspension - Brakes - Steering 1 02-07-2003 08:15 PM
Frame desighn help Halloweenking Suspension - Brakes - Steering 6 04-24-2002 05:38 PM
Rear Frame Kit-JEGS beetle9 Suspension - Brakes - Steering 0 04-18-2002 05:51 AM
repairing a cut up frame jniolon Suspension - Brakes - Steering 3 04-12-2002 07:42 AM
