MustangII whats the best to narrow it - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2008, 09:30 PM
I am trying to find the best way to narrow a mustang II frt suspension from the stock 56.5in. track width to 48inches. I know i"ll have to cut down the crossmember but you still need to do something to shorten the rack. Any ideas ?
Old 07-29-2008, 06:56 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
no need to shorten the rack. just cut and rethread it.
Old 07-29-2008, 12:40 PM
life is a temporary assignment
I built the frame in my 32,I used a pinto front end,Which is the same as the mustang II .I cut it,and narrowed it 4'' in the middle.I then reversed the spindles where I could put the rack on the back side of the cross member.I used a Geo metro rack.Everything worked out great.Never did a front end alignment.At 65 you could turn the wheel lose.It drove very nice.
The front arms you see on the frame,Held the battery, And the pillow blocks for the tilt front end.
ID:	31539   Click image for larger version
Old 07-29-2008, 01:37 PM
39Hemi's Avatar
Unisteer has custom rack and pinion where you can specify what you need, you might want to check them out. You need to make sure the pivot points on the rack matchup with your suspension pivot points or you will have problems with bumpsteer.
Old 07-29-2008, 02:50 PM
That is correct. imagine a line from top pivot point on the a-arm,To the bottom a-arm pivot point.The pivot point on your rack should fall on that line also.
http://www.heidts.com/pdf/Understanding_IFS.pdf
$$$ to narrow 10 bolt ? Vortech 4.3 Transmission - Rearend 8 09-07-2007 05:35 PM
Gotta narrow a diff - never done it before Sidn Hotrodders' Lounge 7 04-02-2007 08:44 AM
WTB: Narrow Slot Mags wolfeman Hotrodding Basics 12 01-14-2007 01:50 PM
Mini tub, narrow rear first or buy wheels first? CHASINGJR Transmission - Rearend 3 09-20-2006 11:21 AM
How to narrow a dana 70??? dodge47 Transmission - Rearend 0 06-20-2002 03:53 PM
