My 1988 S10 Build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #16 (permalink)
Old 03-31-2013, 09:14 AM
Camaro_Nut2001's Avatar
Drag Racing Lover
Last journal entry: '68 Impala Project
Originally Posted by runn141 View Post
here is what i had to do get clearance between the fan and radiator. i had to do this because the mounts allowed the fan to slightly rub the radiator on the drivers side at high rpm.
Im not gonna be able to do this as the a/c condenser wouldn't fit. The JTR manual shows this but my urinary meds won't let me handle the heat so I have to run air if I want to drive in the summer. Thanks for the advise and pictures though.
  #17 (permalink)
Old 03-31-2013, 09:48 AM
s10
I also recommend a Griffin radiator and a dual electric fan. Gives you all the clearance you could ever need up front. Works great on my 91 S-15 and she runs 180 all day at the track or the street cruises.
The Following User Says Thank You to snakebit68 For This Useful Post:
Camaro_Nut2001 (03-31-2013)
  #18 (permalink)
Old 03-31-2013, 10:18 AM
Drag Racing Lover
What thermostat are you runnin? Do you drill a couple of holes in your stats? I put a CoolCraft radiator in my '69 Chevy truck and am very happy with it. Keeps that big block runnin between 160-175 anywhere you drive it. I run a 165 stat with an 1/8th inch hole and a 1/16th inch hole drilled in it.
  #19 (permalink)
Old 03-31-2013, 10:19 AM
Drag Racing Lover
That is a very nice lookin truck you built SnakeBit.
  #20 (permalink)
Old 03-31-2013, 10:42 AM
s10
Thank you...it looks better in pictures. It runs really well...lookin forward to getting the narrowed 12 bolt in it next week with the ladder bars. Perhaps then I can get some consistent launches. I really want to use the two stage NOS and spray 275 at the top end. Looking to get into mid 9's with it.
  #21 (permalink)
Old 03-31-2013, 05:39 PM
runn141's Avatar
Originally Posted by Camaro_Nut2001 View Post
Hey feller, thanks very much for the photos and the advise. I am gonna do this as my exhaust guy Jackie will really thank me.
heres a couple of pics of it in the truck before running the exhaust.
Name:	crossmember s10 (Medium).JPG
ID:	72780   Click image for larger version
Name:	driveshaft loop (Medium).JPG
  #22 (permalink)
Old 04-01-2013, 06:46 AM
Drag Racing Lover
here is an idea you can do with 2 trans cross members that i done. makes running exhaust alot easier under these trucks
Is that two S10 crossmembers that you made the one out of? I noticed in your other two photos with it installed that it looks turned around, the right side that bolts to the side of the frame is now on the left side where originally the crossmember sits on top of the frame. Thanks again for the advice, looks really good.
  #23 (permalink)
Old 04-01-2013, 12:51 PM
runn141's Avatar
the other is the tubing i have tied in for a drive shaft loop. it also helps keep the frame from twisting.
  #24 (permalink)
Old 04-02-2013, 10:12 PM
Drag Racing Lover
Ok yep, I see what you're talking about on the square stock but Im asking about the crossmember you made. Did you use 2- S10 crossmembers to make that one or what crossmembers did you use to make the one pictured? I ordered the mounts from the link you posted, the mounts I have came off an S10 with a v-8 but the rightside mount doesn't have the hole cut. I plan on swapping out the frame mounts to 2.8 mounts and starting the firewall mods Thursday and will post pictures. Ive got to tap the stud bosses in my buddys Pontiac heads tomorrow and hopefully, if the good Lord is willin, put my new CDI box on my '68 Impala. We're suppose to have very nice weather Sat. and Sunday so I want to get some cruisin action goin on, lol.
  #25 (permalink)
Old 04-03-2013, 10:01 AM
runn141's Avatar
i took two s10 crossmembers and made one. and the mouns i have dont have the hole cut, i think those are for the 4x4's.
The Following User Says Thank You to runn141 For This Useful Post:
Camaro_Nut2001 (04-04-2013)
  #26 (permalink)
Old 04-09-2013, 09:20 PM
Great to hear someone interested in building an S-10.
I built an 89 S-15 with a 383 with a killer edelbrock MPI system, 700R4 trans, FlowMaster super 40 dual exhaust with electronic exhaust cutouts. If you need any direction, feel free to ask... i will be glad to help.
I do recommend the set back mounts mentioned earlier. The JTR manual is interesting. They do show where to cut a small hole to access the motor mount bolts. after changing, weld flat steel over the cut area. I think the best idea (which I did) was eliminate the engine driven fan for a early 90's ford taurus fan. Better cfm's than the high performance racing fans and pretty much bolts up to the corvette radiator (also recommended and did). The corvette radiator is only (I think) 1 1/2 thick and provides plenty of cooling, even in OK paired with the taurus fan. This setup provided plenty of cooling without much radiator support mods. I did clip the top of the radiator support and weld some steel across.
Have fun!!
The Following User Says Thank You to jcast1411 For This Useful Post:
Camaro_Nut2001 (04-14-2013)
  #27 (permalink)
Old 04-10-2013, 07:40 AM
ronbuhg's Avatar
nice project there !!!! I have a 85 S10 extended cab myself and wanted to advise you that if your going with an auto trans.. to consider Mr. Gasket's tranny dipstick set~up... it's about half the price of a Lokar,even though that's what I have now... didn't find out till after I bought it of course !!! LOL !!!
The Following User Says Thank You to ronbuhg For This Useful Post:
  #28 (permalink)
Old 04-10-2013, 09:42 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
For more info than you can process at one, (or even several), sitting(s), check out v8s10.org. Most of us there would rather use the JTR manual as bird cage liner. A fan that works GREAT on S10 V-8 swaps is the 98 up 3.8 Chrysler Intrepid dual fan setup. If fits the stock 4.3 radiator like it was made for it, and also fits my 19x31 Be-Cool. There is a build thread on the above site in Member's Projects under the same screen name as here that has LOTS of pics and great ideas. I used my stock 4.3 serpentine setup and it works great. Another thing that many of us do with the serp setup is to use a late 80s Vette water pump and a Mercruiser W/P pulley for a LOT more room up front. My 93 shortbed has a 430 hp Vortec head 363 in it, with a 700R4 and a narrowed 3.73 posi Exploder 8.8 in it, Camaro LS brakes up front, and the Exploder rear discs. It's my daily driver, but it also goes high 7s in the 1/8, and tows my race car to boot,
The Following User Says Thank You to Rickracer For This Useful Post:
  #29 (permalink)
Old 04-10-2013, 12:35 PM
Blacky's Avatar
Blacky
Last journal entry: Home
Other Info Sources
This forum is great and you are getting good help. Here is another forum that should tag with your book quite well. Lots of good pictures. I am disabled as well so I have much more time to figure out how to do something than I have the energy to do it. Here is the site.
V8S10.ORG Board index Swap Tech General Swap
The Following User Says Thank You to Blacky For This Useful Post:
  #30 (permalink)
Old 04-10-2013, 03:20 PM
Rickracer's Avatar
Hey Blacky, that's the same forum I mentioned above, , if you're from there, you know who I am,
S10 build mreagin03 Hotrodding Basics 4 11-01-2010 08:18 AM
Cheap 1988 S15 Hot Rod Build s15hotrodder456 Introduce Yourself 2 10-16-2010 06:40 PM
1988 chevy s10 with 305... need help!!!! kaginromeo Hotrodding Basics 4 04-28-2010 09:52 AM
S10 build up elchicano General Rodding Tech 1 04-15-2007 08:11 AM
v8 S10 build Surfer1130 General Rodding Tech 34 01-12-2005 07:05 PM
