My 1988 S10 Build
The time has finally came to start my S10 build. I am building this truck for my daily driver. A friend I used to work with bought this truck new in '88, drove it for several years, then got it a little to warm and blew a head gasket. He parked it about six years ago with the plan of having it fixed. I did try to buy it a couple of times with no luck, then one day about a year ago, just out of the blue, he called me and said if I wanted it to come get it. I didn't waste any time, lol. The truck is a factory A/C truck with a 2.5, which is now locked up, and a 5-speed transmission. My plan is to pull both of them and replace with a vortec headed 350 and a TH350 trans. I have built the motor, done the head porting myself, and my buddy Turbo built my TH350. I'm going back with the A/C, a serpentine belt setup if I can find one and if not, just go with the V-belt.
I am taking my time on this one, my body is telling me to, lol. Also, I am biding, EBay, on a used copy of "Chevrolet S-10 Truck V-8 Conversion Manual" by JTR. for some ideas that might make this easier on me, not to mention work out a little better than what i've come up with. I am now into physical theraphy again due to my legs going completely numb Jan. 29th of this year and a short stay at UT hospital. One real positive thing that came out of that experience, other than me being able to walk again, is I quit smoking. Anyway, here is where I am as of yesterday http://www.hotrodders.com/forum/atta...1&d=1363528748 http://www.hotrodders.com/forum/atta...1&d=1363528748 http://www.hotrodders.com/forum/atta...1&d=1363528868 |
| The Following User Says Thank You to snakebit68 For This Useful Post: | ||
Camaro_Nut2001 (03-17-2013) | ||
s-10
I actually mocked it all up and drilled holes in the floorboard to access the bolts. Just used rubber plugs to fill the holes. Makes access alot easier if you ever need to drop the trans. Its nearly impossible to get the bolts out with the engine in place...unless you are a contortionist for the circus. I also cut away the firewall and floorboard seam where they join and just ran a weld acrossed it. Otherwise that lip causes alot of grief on engine install and exhaust and wiring routing.
s10
My prayers are with you, your grandmother, and your entire family. Lets all pray for the best.
Yes, I set my engine back 1". I recommend mocking everything up first if at all possible. You can only go so far back before you begin to have issues with the exhaust headers. There are some great headers out there designed to fit around the frame rails of an s-10, and they look great too. Mine are Hooker headers that are pieced together around the frame...although they function well, they make removal impossible with cutting them out. Never again on the "piece together" and weld ones! I'll get the ones that wrap over the frame and exit on the outside of the frame rails rather then on the inside. Just a few tips to save you some of the headaches I've encountered over my build.
Camaro_Nut2001 (03-22-2013) | ||
Thank you very much. I am probably going to stick with the headers that wrap over the frame. I also read in that book the rear-end is setting forward by 3/8th of an inch of the center of the wheel well and you can buy, or make your own, plates that set the rear-end back and centers it along with not having to cut my driveshaft. Like I said, Im gonna be doin several mock-ups lol. Hopefully my grandmother continues to be stable and I can get out in my garage and get the 2.5 out along with clearing my head a little. Almost forgot to ask you, did you use the mount that allows the 2.8 frame mount to stick through on the passenger side? The mounts I have don't have the hole for that.
s10
I actually cut the old ones off and welded the set for a 350 to the frame. Keep in mind I also had to cut out a section of the crossmember just to get the oil pan to drop into the engine compartment. It has to be notched pretty good. If you use a set of motor mount adaptors I believe your engine will sit up higher in the engine compartment and you may not have pan clearance problems. But then, you have to deal with the seam from firewall to floorboard. Always going to be one thing or another. Keep me posted as you get started.
Camaro_Nut2001 (03-29-2013) | ||
I finally got the old motor and trans out yesterday. I plan on pressure washin everything and start on the modifications that has to be made Tuesday but it depends on how my body acts. I think I have enough POR-15 left from my '69 SWB build to do the front portion of the frame and the complete frontend, after repairs of course, lol. The upper control arm bushings are dry rotted pretty bad so I plan on replacing them along with any other bad parts that I find. Also, i'm gonna give the complete brake system some attention before I go back with my v-8. Unless I find a bad spindle I'm gonna leave the stock ride height, just new shocks. There are more things I plan on doing before I put the new motor in but for now here are a few pictures
S-10 Truck V-8 Conversion Mounts, S10 V8 Conversions, Stealth Conversions
only way to go in my opinion. Last edited by runn141; 03-29-2013 at 04:53 AM. |
| The Following User Says Thank You to runn141 For This Useful Post: | ||
Camaro_Nut2001 (03-31-2013) | ||
here is an idea you can do with 2 trans cross members that i done. makes running exhaust alot easier under these trucks
using the S-10 Truck V-8 Conversion Mounts that are in the link i posted. you will have to modify the frame for the fuel pump to be able to be removed when needed. because the mounts allow you to slide the motor more to the passenger side for more driver side exhaust clearance.
here is what i had to do get clearance between the fan and radiator. i had to do this because the mounts allowed the fan to slightly rub the radiator on the drivers side at high rpm.
Hey feller, thanks very much for the photos and the advise. I am gonna do this as my exhaust guy Jackie will really thank me.
Thanks for the info. Im runnin an electric pump on this truck but I may go ahead and do this in case I ever want to change to a manual pump.
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Blacky |
| S10 build | mreagin03 | Hotrodding Basics | 4 | 11-01-2010 07:18 AM |
| Cheap 1988 S15 Hot Rod Build | s15hotrodder456 | Introduce Yourself | 2 | 10-16-2010 05:40 PM |
| 1988 chevy s10 with 305... need help!!!! | kaginromeo | Hotrodding Basics | 4 | 04-28-2010 08:52 AM |
| S10 build up | elchicano | General Rodding Tech | 1 | 04-15-2007 07:11 AM |
| v8 S10 build | Surfer1130 | General Rodding Tech | 34 | 01-12-2005 06:05 PM |
