My 1st self taught attempt - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2010, 08:31 AM
With some great advice read on this site, as well as with books, etc over the years I finally have a machine and did my first attempt.
I have learned in life most often I learn more from doing something wrong then I do from doing it right. I take those lessons as education and not wasted effort.
Lessons I learned on my first attempt (seat bottom only so far).
If you have 4 panels coming into a corner, like painting don't sew into the corner, combine 2 panels to make 1, then combine them avoiding sewing into and stopping in a corner.
Stretching them tighter is not always better. I thought I would put the listing wire on a bit tighter thinking it would stretch out some and it may, but I went a little too tight I think.
With that said here is the picture of my 1st attempt, all suggestions are welcome you won't hurt my feelings.
Old 08-24-2010, 09:29 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
How does it set..will it be comfortable on a long trip for you? Does look good from here though I would like to see it a bit smoother and I personally would have brought the red out a bit more in the front... but not to worry just see what you can do better the next time..Just the cost of education and I do approve heartily of the guys who just get it together and go try..
Sam
Old 08-24-2010, 02:01 PM
DanTwoLakes's Avatar
Wiki Edits: 22
What is the seat out of? If you tighten down the listing wires too tight, it will just pull in the sides. I would take it off and use listings like the original seat had. In general, if the seat cover ends up being a little loose, it's easier to add some foam to the top of the seat than to tighten the listings down.
Old 08-24-2010, 03:56 PM
Basically an S10 so there is listing wires in the middle which are the ones I pulled too tight.
Old 08-24-2010, 04:03 PM
Wiki Edits: 22
I assume when you say in the middle, you mean to the left and right of the red insert, right?
Old 08-24-2010, 04:23 PM
Correct, I plan to cut the backs down shorter also.
1st attempt at fiber glass 68Birdman2 Interior 9 01-31-2010 12:18 PM
My 1st attempt at rendering a drawing ShadetreeBody Hot Rod Art 1 07-21-2008 06:09 PM
1st attempt at door panels Bluepen Interior 3 09-29-2006 01:29 AM
1st attempt at painting!! Pony Body - Exterior 4 05-26-2004 12:38 AM
th350 1st gear manual shift problem desman Transmission - Rearend 6 02-08-2004 03:15 PM
