my 2.3 ford engine will not start - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2003, 04:17 PM
pintoperformance's Avatar
New Member
Hello,
New to this site, hope someone can help
have a 1978 Ford 2.3 four banger-has been modified--I had machine shop change out cam.. when I reinsalled head--and tried to fire engine--it would not start-belched through the carb.
checked plug wires they are hooked to right sparkplug
all vacum lines hooked up
followed procedure for setting engine up ie
timing mark on camshaft sprocket alinged with pointer--timing mark on crack aligned and distrbt buttom pointing to #1 plug---have I missed anything--could it be that the timing is 180 degrees out and if so how do I correct the problem
Mike
Old 10-05-2003, 05:07 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hello.
Welcome to the club.
Im not a big Ford person, but I know when you line the dots up on a sbc it is always 180 out. Or at least mine always is, lol. Id retry the timming. Redo the distributor or maybe first, relook to make sure all the wires are correct. Not much help, but I sure try. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
