My 231ci Makes Noise When I Accelerate - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2003, 06:58 PM
7skylark6's Avatar
Angry My 231ci Makes Noise When I Accelerate
I have a 76 Buick skylark with a 231 from a 84 Grandprix.
When i'm at a stop, i press on the gas hard (Imagine you want to burn rubber) it makes a noise in that moment. If i let go of the gas the noise stops. It doesn't make that noise while the car is running over 15mph.
Only when i press it hard. If i start off pressing the gas normally (like a 70 year old person) it doesn't make that noise. It sounds just like if you would stick your hand or a stick while a metal fan is on in your house.
I checked if nothing hits on the top , front, sides of the engine and i believe it is on the inside.
Ive never taken the car to a mechanic. I have this car since august. If anyone knows, can you please help me?
!Oh Yeah!
If i do the same thing in reverse it doesn't make the metal scrapping noise!
Old 12-09-2003, 07:41 PM
badknuckles's Avatar
you talkin to me?
im not sure anyone can help you with that post you didnt state what kind of noise where its coming from i think this is what auto part was talking about
Old 12-09-2003, 08:04 PM
Nos's Avatar
Nos Nos is offline
maybe in your trans
Nos
N|O|S
Old 12-09-2003, 08:06 PM
toddtheodd's Avatar
not enough info = no answer
Old 12-09-2003, 08:30 PM
4 Jaw Chuck's Avatar
Check your engine mounts and give us more info to go on.
— Han Solo
Old 12-09-2003, 08:37 PM
7skylark6's Avatar
You can hear the noise in the engine. (the center front) it sounds like how i said. Imagine you hit a turning fan with a stick. But harder. Like a metal fan.
I'm not sure if its were the transmission is but it sounds right on the center of the engine.
Old 12-09-2003, 08:40 PM
NAIRB's Avatar
Spark Knock
Sounds like a little spark knock to me, which the early 231 was good at, and it will destroy the engine sooner or later. Aaahh, those early 231s, they ran like crap, and would kick back and run backwards for a second when you shut them off. We've came a long way baby!!!!!!!
Old 12-09-2003, 08:49 PM
7skylark6's Avatar
Well this same noise happens on my dads 1973 ford 350. Exactly!!
Oh Yeah my 231 for being stock if it didnt have that little defect it whoops ***. Not bragging or anything. I also have a 231 in my 81 century and runs good. They are family type cars
Old 12-09-2003, 09:57 PM
poncho62's Avatar
Wiki Edits: 5
If it is spark knock (pinging), you timing is too far advanced. Set it back until the noise stops.
Also, try higher grade gas.
Old 12-09-2003, 10:53 PM
check you fan belt for tension, I have seen them jump and slap with no squeak and make a hell of a knocking.
Old 12-10-2003, 06:25 AM
Moby302's Avatar
Psychotic
I agree with Poncho, check your timing, my one car did that, only on take off, like a whole lot of metal beer tops in a bottle.
Old 12-10-2003, 06:54 AM
NAIRB's Avatar
"Whoops ***"????
Old 12-10-2003, 08:25 AM
drlindz's Avatar
My 231ci Makes Noise When I Accelerate:
Then don't accelerate!
J/K
Old 12-10-2003, 11:36 AM
Moby302's Avatar
Psychotic
Old 12-10-2003, 03:57 PM
bigblockbill's Avatar
ck for a drivers broken motor mount
mount could be broken causing the fan to hit the fan shroud
