My 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2006, 09:50 AM
dale_gribble86's Avatar
My 350
I have recently started my first engine build and am wanting to turn my 350 into a stroker motor. By putting a 400 crank in it do I change rods or keep the 350 rods? How large of a valve should I go with?
Micah
Old 01-22-2006, 09:54 AM
poncho62's Avatar
Wiki Edits: 5
No, you can't bore it that much......BTW, a "Stroker" is an engine with a longer stroke crank installed.
Most guys put a 400 crank in their 350s and get a 383.
Old 01-22-2006, 06:52 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You can go with the 5.7" rods and buy pistons for a 383 or you can use the 5.565" rods and use a piston for a 350.
Valve size will depend on what you're doing with the engine. Most aftermarket heads come with 2.02/1.60 valve sizes while factory heads can be found with a few different valve sizes in them.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
348 or 350 delimma 62ImpalaSS Engine 12 05-17-2006 11:03 PM
