my 350 block dilemma - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2010, 09:48 AM
I have 2 350 blocks. both are 3970010 pre 1980 standard bore blocks. one is a 2-bolt main block that is in beautiful condition, not hardly even a ridge at the top of the cylinders. the other is a 4-bolt std bore in pretty good condition...the only problem with it is it looks like something fell on it while sitting in the shop and put a nasty gouge in the very top of one cyl. I know this didn't happen while the motor was running because the piston and cylinder wall was in perfect condition. the machine shop said they would have to sleeve it to save that cyl.
My target is around 400 hp. I plan on having all the basic machine work done either way. and I'll run main studs with either engine. my question is this: which is better for the hp range I'm planning, to have a 2 bolt main that is in good shape from the beginning, or a 4-bolt that is sleeved? its going to cost an extra $100 to sleeve the cyl. and before anyone suggests it, I'm not going to spend the $500+ to put splayed caps on. thanks!
edit: I forgot to mention that this will mostly be a street driven motor shouldn't see over 6k r's much if ever. maybe an occasional run down the strip.
Old 10-08-2010, 01:18 PM
If you don't plan on revving it hard then the 2 bolt will be fine. I would not use main studs in this application.
If you plan on revving it over 6,000 then I would get the splayed caps- you can cry about the price all you want, the tears will really flow when you spin a main bearing or worse though.
Old 10-08-2010, 01:26 PM
ericnova72's Avatar
More for Less Racer
First question, Is the gouge in an area where the ring will touch it during it's travel?? If not, if some remnants of the gouge remains above the top ring travel at TDC after boring it doesn't matter, if the rings won't get into it.
Old 10-08-2010, 02:11 PM
actually it doesn't go down into the cylinder far enough for the top ring to touch it. what I am actually worried about is the head gasket sealing. the gouge goes about halfway into the "ring" on the head gasket on the deck surface. the machine shop said they could use an 1/8" thick sleeve and they would have to cut it past were the gouge is to put the sleeve in, and then surface it. or maybe if I could find a head gasket with a wider sealing ring around the cylinder it could possibly still seal. it is too deep for them to just surface the deck to get it out. any ideas?
Old 10-08-2010, 02:29 PM
Run a 400 sbc head gasket.
Old 10-08-2010, 03:13 PM
ericnova72's Avatar
More for Less Racer
Yep, surface it and run a 4.190"-4.200" bore gasket should do it.
Old 10-08-2010, 03:52 PM
GMC boogie's Avatar
Just use the 2 bolt block you have that is in good condition,plenty good for 400hp.
Old 10-11-2010, 11:02 PM
FastOrange's Avatar
i would just use the 2-bolt block, not like your putting it into a stock car thats gonna see 6500+RPM all day.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
350 roller block questions. MikeAhrado Engine 7 08-12-2010 06:45 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
How much stroke is too much for block with 350 mains? flyin99 Engine 11 09-25-2007 07:58 AM
