My 350 build up, help me please - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-31-2005, 05:36 PM
montea's Avatar
tryn to learn
Thanks Bobby im gona take it back in first thing tommarow morn
  #17 (permalink)
Old 05-31-2005, 09:02 PM
well, thats def. my opinion on things
i know that scratched cam bearings will drop oil pressure, i wouldnt truest someone who would do careless work like that,
and i am no expert engine builder, but i would look somewhere else for people who do quality work.....
as fas as the crank goes he may be correct, but id get someone elses opinion just because i dont trust anyone who does below par work in the first place
  #18 (permalink)
Old 06-01-2005, 01:22 PM
montea's Avatar
tryn to learn
i just got back home with my block. he said why it had the grey fim on the block was thats just the way it comes out of the hot tank like, and said i supposed to wash it down with soapy water before i assemble the engine. and he said cam bearings were scratched because the installation tool just does that. and he put the other frost plug into the block.
i took the block to another machine shop and he told me they supposed to give it to me ready for assemby and nothing should be on the block like the grey film that was on mine. the cam bearings looked fine to him but he said they smooth them out to get rid of the scratches. oh ya and they woulda done it all for $30 cheaper o well least i know where to go now. picked up a set of rings too.
now i just need some advice on
#1 - proper way to clean the block and what do spray the internal to stop from rusting?
#2 - The crank, how much is to much? is 2 thousands over the original to much to reuse with a new set of standard bearings or should i be getting a crank kit?
#3 with the 305 heads "-14014416...80-86...305..........1.84"/1.5" valves, 58cc chambers" what will my compression ratio be and will i still be able to run regular 87 octane?
Thanks again everyone!
  #19 (permalink)
Old 06-01-2005, 01:53 PM
DoubleVision's Avatar
The rule of thumb on clearences is, anything under .001 is not enough, anything over .003 is too much, so if you get standard bearings you`ll be fine. You can get bearings that are .001 thicker than standard, but before I did so I would have every bearing journal mic`d and recorded before I ordered them, because if you had one or more journals that were only .001 it maybe too tight and it would spin the bearing, so going with standard would be the safest bet. as for cleaning, there`s no such thing as clean enough, do just as I said in my first post, clean it clean it and clean it some more, soapy water don`t cut it either, I like to use sea foam or any other heavy duty cleaner to clean the bores, you can buy a new toilet brush that will fit the bores nicely, use a spiral motion with up and down strokes, use the WD40 and paper towel method to see if you see any gray on the paper towel, when it`s clean there will be none. afterwards I would wash it with soap and water, then use compressed air to dry it, then spray down the machined surfaces with WD40 to prevent rust, remember, clealiness is horsepower. The compression ratio with a .041 thick gasket will come in around 10:1 and it`s likely you`ll need to run higher octane fuel, but I think if you watch the timing curve carefully it`ll be okay on 87 octane, The figure I gave is estimated, for it to be exact you`ll have to use a compression calculator. You could always use a die grinder and carbide cutter to open up the chambers some if need be to lower the compression ratio.
  #20 (permalink)
Old 06-02-2005, 03:10 PM
montea's Avatar
tryn to learn
i just bought a Crank kit and it set me back another $270 that leaves me with $0
he took at look at my heads and said they looked fairly good and will charge $350 for everything unless a valve is needing replacing or somthing, but from the looks of it he said they should be all fine. he also reccommended that since i am going to use a RV cam i should be getting some new valve springs, just like the LT1 springs for a extra $80. if not i have the chance of breaking the springs/rocker arms. do you guys think i really need that to be done too? extra 80 bucks
  #21 (permalink)
Old 06-06-2005, 12:24 PM
montea's Avatar
tryn to learn
just picked up a rebuilt set of 14014416 305 heads for the motor
-will the original rockers and pushrods work with these?
-will the stock springs work ok with the edelbrock rv cam? machine shop guy said i will be breaking the springs and rockers if i dont replace them with new less coil springs that will stand the higher lift cam.
  #22 (permalink)
Old 06-06-2005, 11:14 PM
circletrack62's Avatar
hey you can get a complete rebuild kit through northern auto parts for like 150 bucks, i would also have the rods checked and get a new crank, also new pistons. just rember to take your time and do things right the first time. go ahead and get new push rods they are only like $15 and he is right about the springs you need a stiffer spring. crane has a set called z28 springs that will work great.
  #23 (permalink)
Old 07-02-2005, 08:16 PM
montea's Avatar
tryn to learn
just fired the motor up today for the first time and made me happy to see it running good
what would you guys suggest for timing it? i set base to 11degrees and vacumm to 10 degrees on ported vacum. i would like to run regular 87 octane if possible.
Thank you
  #24 (permalink)
Old 07-19-2010, 07:39 PM
LATECH's Avatar
pantera is right. I looked at the pictures and the bearings are gouged but even worse they are installed wrong. there are three different positions for the oil hole to be at for the five bearings. Also if you CAREFULLY test fit the cam before assembly ( I recommend) you should be able to spin it easily. I have sent engines back to have bearings installed again as they can be installed a little crooked if your machinist is in a hurry.I finally bought my own tool and I do it myself. You will feel a drag or it will be hard to spin from binding on the bearings. Also NEVER sand a piston . That removes material from an allready worn part and with aluminum ... abrasives will Embed themselves in the piston and munch down on the cylinders.Not to mention wear out everything else inside that moves.Late 70s heads are fine.Do your homework on chamber size and shape. there are two intake valve sizes that guys refer to whentalking about a chevy head. A 172 is the smaller Generally used on 2 bbl intake motors and a 194 which is used on 4 bbl intake motors .Both have benefits and drawbacks. Remember for every action there is an equal but opposite reaction. Good luck
  #25 (permalink)
Old 07-20-2010, 04:36 AM
This thread is 5 years old.
350 build upgrade cam azbandit Engine 14 06-17-2006 06:00 PM
350 Engine rebuild CamMan Engine 35 06-01-2006 02:32 PM
350 build upgrade cam suggesstions. azbandit Engine 2 02-07-2005 06:23 PM
How to build a 350 insayne Engine 2 11-08-2003 07:14 AM
350 Chevy build Streetmachine Engine 11 12-10-2001 04:31 PM
