Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - My 350 Chokes!
Thread: My 350 Chokes!
Old 05-15-2002, 08:04 AM
middspecauto middspecauto is offline
New Member
change your timing to ten degrees b.t.d.c. and turn your carb adjusting screws in until it barely runs by itself(chugging and popping) and then turn them out by one fourths until it smooths out. take it for a test drive and just move the distributor a couple degrees at a time until it starts losing power again and then set it back to your last setting. seen this problem a million times. when you change one variable they are all affected. try it, what do you have to lose?
