My 350 dies when idling - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2004, 01:22 PM
rbfpezcore's Avatar
Not fast, but loud as hell
I'm new to the whole old car restoration thing, but I just bought a 74 nova ss with a 350 and it starts up fine and sounds great, but when the car is idling and I'm not giving it gas, its boggs down and dies. I don't know what the problem is, I'm just learning. Can anyone help? Thanks
Old 04-25-2004, 01:43 PM
Rubberman2003's Avatar
Do you have a fuel pressure gauge?
Old 04-25-2004, 03:23 PM
Tazz
engine dies at idle
there is a rocker on the linkage on the side of the carb. Adj the screw In on the side of that rocker. The screw will have a spring on it, turn it in 1/2 a turn.
Tazz
Rat Rods Rule!
Old 04-28-2004, 01:45 PM
rbfpezcore's Avatar
fuel pressure gauge
Yes I do and I think it is operational, its balances around 40 when the car is on.
Old 04-29-2004, 12:48 AM
Siggy_Freud's Avatar
Is the car fuel injected? Carbs take 4-9 psi, TBI (throttle body injection) takes 9-12, and Multiport takes anywhere from 40-60 or so.
CHeck for correct pressure, vacuum leaks, proper idling position. If its fuel injected check and readjust the TPS or Idle air control valve.
With computer controlled vehicles get pretty technical however so if your new to the car thing I hope you dont have to jump right into that kinda setup.
Give us a lil more info and we might be able to help further.
Good luck.
Bringing history and technology together.
Old 04-29-2004, 10:07 PM
New Member
What kind of carb is it? Is it carberated or fuel injected?
